Thread: I need help writing VBA code
    Aug 2015
    I am new to writing VBA code and would like some help please. I have manage to use a small amount of code and also created a userform and a sheet where data is to be transferred.
    Where i need help is once the userform is populated, i select the transfer button and it then transfers the data to a sheet called records.The entries just find the last row beneath the last entered entries.
    All 3 combobox`s and textbox must have entries before the data can be transferred.
    Is this a possibility?
    Thank you
    Chris
    Aug 2015
    I have since added some code but it places down the first column instead of across the sheet. What changes do i need to make to get the entry to go across the columns in the same row?
    Thank you
    Jul 2012
    See in attach.
    I renamed ComboBox and buttons and I put a code to retrieve data from ComboBox in table.
    Hope it help.
    Aug 2015
    Ingolf, yes thank you for help
  1. Replies: 2
    Last Post: 01-27-2015, 08:29 PM
  2. Replies: 0
    Last Post: 01-24-2015, 03:50 PM
  3. Re writing a code?
    By justme1052 in forum Excel Help
    Last Post: 01-23-2014, 09:21 PM
  4. Replies: 1
    Last Post: 08-23-2013, 06:33 PM
  5. Shorten VBA Code By Removing Redundant Superfluous Code
    Last Post: 08-15-2013, 09:09 PM
