Hi all, new to this forum and forums in general, so I hope I posted my question correctly and that I am clear enough.
I have two columns where column "E" has just numbers that are 6-10 digits in length and the second column "H" starts with an alphanumeric character (lets say the letter B) then 6-10 digits after it.
The columns go from E1: E273 and H1:H273. (not always but long enough)
I need to remove the first character in column H then compare the results to column E. If there is a different, I need to know and that can be up to your discretion, as long as I can see the results.. I could be notified by color, by putting a 0 or 1 in a different column, or by dropping the number in a any different column.
What I have tried is creating a blank column G and putting in it the formula
=REPLACE(H1,1,1,"")
which removed the first character in column H and showed up in column G
Then I put in blank column F the formula
=IF(ISNA(MATCH(G1,E:E,0)),G1,1)
which only copied the results from column G to column F as if to say they were different. If they were the same column F would have the results 1 and not the number.
Not sure what I did wrong. And if it can be done through a VBA macro, that would be fantastic. I will be using it a lot.
EX.
Colum E
14624720
7802049
24842259
28675186
32334880
30466791
2234169
24717605
45069143
7825783
16875105
13656190
9447593
Column H
B14624720
B7802049
B24842259
B28675186
B32334880
B30466791
J2234169
J24717605
J45069143
B7825783
B16875105
B13656190
B9447593
Thank you for your time and help,
Dave
