Results 1 to 10 of 11
Thread: Left and Right Mouse Click Event
    Why do you want to right-click? You can use a normal click, and the assigned macro will run even if the sheet is protected. And if you want the shapes also to be unprotected, then use
    Sheet1.Protect UserInterfaceOnly:=True, Password:="xyz", DrawingObjects:=False
    Oct 2011
    Hallo
    Still to solve the problems of selection wonder how the subject should be written the following code:
    Sub Test()
        ActiveSheet.Shapes("Picture 309").Select        'I select the object
        ActiveSheet.Shapes("Picture 309").Deselect      'Here I would like to deselect the object
    Obviously, the code does not work ...
  1. Set Adjust A Button Top Left Position Programmatically
    By jeffrey159 in forum Access Help
    Last Post: 02-02-2013, 06:24 PM
  2. Sort data sheet by right_click of mouse
    Last Post: 12-08-2012, 07:34 PM
  3. Replies: 2
    Last Post: 02-29-2012, 08:24 PM
  4. Replies: 3
    Last Post: 12-07-2011, 09:59 PM
    Last Post: 11-08-2011, 08:52 AM
