Thread: Inconsistent "greater than" and "less than" calculations
    Feb 2015
    Hello, I have a column of cells into which I want to calculate some basic pass/fail criteria based on this formula
    =IF(ISBLANK(C28),"",IF(D28>0.1,"Fail","Pass"))
    The data for D28 is coming from another calculation, which is working correctly. If the result of the calculation is exactly 0.1, then most of the time I get a "Pass" return - which is incorrect (0.1 is not greater than 0.1). I say most of the time because although it happens this way most of the time, there are certain cells which give the correct answer.
    ..any idea what's going on?
  1. VBA Versions of my "Get Field" and "Get Reverse Field" formulas
  2. Reversing a "First Middle Last" Name to "Last, First Middle" Name Format
    Last Post: 01-06-2014, 10:04 PM
  3. Replies: 4
    Last Post: 09-09-2013, 05:13 PM
  4. Ordinal Suffix (i.e., "st", "nd", "rd" and "th")
