Thread: Single calendar (Userform) for multiple textboxes
    Apr 2012
    I herewith attach sample workbook with 2 userform. i want when i click on textbox on userform the calendar should pop-up and selected value on calendar userform should reflect on textbox. I dont want to use ocxCalendar for this. here is want to user single calendar (Userform) for multiple textboxes.
    I am getting error in code, i will appreciate any help on this.
    Member p45cal's Avatar
    Oct 2013
    try changing
    Public cbodate As TextBox
    to
    Public cbodate
    Excelfun, that recommendation by p45cal should work for you. I would also recommend using
    Public cbodate As MSForms.TextBox
    instead of
    Public cbodate
    which then makes it a variant
  1. Replies: 4
    Last Post: 03-06-2014, 08:04 PM
    Last Post: 02-06-2013, 09:37 PM
  3. Replies: 2
    Last Post: 12-19-2012, 08:28 AM
  4. Converge Data From Multiple Columns To Single Column
    Last Post: 12-14-2012, 10:55 PM
  5. Concatenate Multiple Lookup Values in Single Cell
    Last Post: 04-06-2012, 09:07 PM
