Results 1 to 5 of 5
Thread: Formula To Remove Part Of Text Based On It's Position In A Sentence
    Dec 2014
    Thanks in advance for any/all help with a newbie.
    I'm searching for a method to extract all values after the 3rd space from the right... with the values posted to separate column -and finally, re-combining the extracted string with only the left values of the original string up to and including the last "/"
    Description:
    987654321 6 Snickersbars11/14/14/HD,X 1.50 4.40 7.50 ---> want string: 1.50 4.40 7.50 in separate column... finally
    ..want to rebuild original description with only the values up to (and including) the last "/" and the string just extracted.
    Desired outcome:
    987654321 6 Snickersbars11/14/14/ 1.50 4.40 7.50
    I have a simple file if that helps?
    Thanks greatly. Mike
    Dec 2014
    Thanks Rick but your post doesn't help?
    I'm time crunched and tried two websites - hoping that more "bait in the water" would gain me a faster solution.
    I didn't know that ExcelFox and MrExcel are somehow connected.
    Quote Originally Posted by mydogjake View Post
    ExcelFox and MrExcel are not connected... my message wasn't meant to help you... it was meant to help other volunteers who might read your question. See here for why what you did is considered a problem...
    http://www.excelfox.com/forum/f25/me...-posters-1172/
    Dec 2014
    Ah. I understand.
    I will graciously (and expeditiously) post links between posts so that others may benefit!
    ..hope I did not offend those who may offer assistance
  1. Replies: 3
    Last Post: 08-15-2013, 01:00 AM
  2. Replies: 3
    Last Post: 06-01-2013, 11:31 AM
  3. Remove Special Characters From Text Or Remove Numbers From Text
  4. Remove Numerics From Text
    By VIMAL CHALISSERY in forum Excel Help
    Last Post: 04-12-2012, 08:43 PM
  5. Remove Zero / Zeroes From Alphanumeric Text
    Last Post: 04-04-2011, 01:16 AM
