Thread: Split Text In To Segments Of Upto X Characters And At The Space Between Words
    Nov 2014
    I have a text string, in multiple cells within a column, that I want to separate, with a maximum of 50 numbers characters per line, but the separation should only take place at a space between words.
    As an example, let's say the text string is this...
    blue red pink floor ground purple tied office hamburger cheese book work today tomorrow yesterday
    and I want to separate it to cells to the right with no more than 50 characters in any single cell. This is how the text should look using "|" to represent the next cell (or possible where a delimiter could be placed)...
    blue red pink floor ground purple tied office|hamburger cheese book work today tomorrow|yesterday
    What i have is not working correctly and locking up excel. Please Help!!
    Example:
    Sub termsSplit()
    Dim rngData     As Range
    Dim Cell        As Range
    Dim arrInput()  As String
    Dim arrOutput() As String
    Dim strValue    As String
    Dim strTmp      As String
    Dim n           As Long
    Dim i           As Long
    Dim bContinue   As Boolean
      '// However you set your range//
      Set rngData = Selection '<--- using the CodeName (better IMO), or, using the sheet's
                                       '(tab) name---> ThisWorkbook.Worksheets("Sheet2").Range("A1")
      For Each Cell In rngData.Cells
        strValue = Cell.Value
        If Len(strValue) > 50 Then
          '// Split the words into an array, using the space as the delimeter.              //
          arrInput() = Split(strValue, " ")
          '// Just clarity  //
          n = 0: i = 0
          '// Outside loop  //
          Do While n <= UBound(arrInput)
            '// Empty the string and set the flag//
            strTmp = vbNullString
            bContinue = True
            '// Test must pass both //
            Do While n <= UBound(arrInput, 1) And bContinue
              '// If projected temp string length will be below 51... //
              If Len(strTmp) + 1 + Len(arrInput(n)) <= 51 Then
                '// ...add a space and the next word. //
                strTmp = strTmp & Chr$(32) & arrInput(n)
                n = n + 1
                '// ...else flip the flag.  //
                bContinue = False
            Loop
            '// Add an element to our output array and tack our built string into it. //
            i = i + 1
            ReDim Preserve arrOutput(1 To i)
            arrOutput(i) = Trim$(strTmp)
          Loop
          '// Plunk the results into a sized range //
          Cell.Offset(, 1).Resize(, UBound(arrOutput, 1)).Value = arrOutput
          Cell.Offset(, 1).Value = Cell.Value
    Try this
    Sub CallSpliter()
         SplitText Worksheets("Sheet1").Range("A1:A100")
    Sub SplitText(ByRef rngSource As Range)
        Const clngSplitLen As Long = 50
        Const clngMaxSplits As Long = 99
        Dim strText As String
        Dim strBreakPoints(1 To clngMaxSplits) As String
        Dim lngSplitsCounter As Long
        Dim lngIndex As Long
        Dim rngCell As Range
        For Each rngCell In rngSource
            strText = Trim(rngCell.Value)
            strBreakPoints(1) = strText
            Do While Len(strText) > clngSplitLen
                lngSplitsCounter = lngSplitsCounter + 1
                If Mid(strText, clngSplitLen + 1, 1) = " " Then
                    strBreakPoints(lngSplitsCounter) = Left(strText, clngSplitLen)
                    strText = Trim(Mid(strText, clngSplitLen + 1))
                    lngIndex = InStrRev(Left(strText, clngSplitLen), " ")
                    strBreakPoints(lngSplitsCounter) = Trim(Left(strText, lngIndex))
                    strText = Trim(Mid(strText, lngIndex + 1))
                    strBreakPoints(lngSplitsCounter + 1) = strText
            Loop
            rngCell.Offset(, 1).Resize(, lngSplitsCounter + 1).Value = strBreakPoints
            strText = vbNullString
            lngSplitsCounter = Empty
            Erase strBreakPoints
        Next rngCell
        Set rngCell = Nothing
  1. Replies: 10
    Last Post: 09-11-2014, 01:58 AM
  2. Remove Special Characters From Text Or Remove Numbers From Text
  3. Extract Certain Characters From A Text String
    By bobkap in forum Excel Help
    Last Post: 05-24-2013, 06:25 AM
  4. Replies: 10
    Last Post: 12-10-2012, 11:28 PM
  5. Replies: 6
    Last Post: 09-26-2011, 07:39 AM
