Results 1 to 10 of 12
Thread: Apply filter and delete rows thru Messege Box
    Aug 2011
    Hi Frineds,
    My macro is not working, i need to apply filter thur message box and delete after the given date rows.I have attached the macro sheet for your reference .
    Kindly help to correct the same.
    Regards,
    Prabhu
    Apr 2012
    Try this:
    Sub MYFILTER()
    Dim W1Startdate As Date
    W1Startdate = InputBox("Please Enter the Start Data in DD/MM/YYYY format")
    range("A2:T" & range("A1").End(xlDown).Row).AutoFilter Field:=7, Criteria1:=">" & W1Startdate
    'range("A4:T" & range("A2").End(xlDown).Row).SpecialCells(12).EntireRow.Delete
    Aug 2011
    I tried, but it is not deleting the record after the given date. i.e it is struck on the filter.
    Sub MYFILTER()
    range("A3:T" & range("A2").End(xlDown).Row).SpecialCells(12).EntireRow.Delete
    Kindly help
    Apr 2012
    Try this:
    Sub NewDelete()
        Dim lr As Long
        lr = Range("G" & Rows.Count).End(xlUp).Row
        Dim i As Long
        For i = lr To 3 Step -1
        If Range("G" & i) >= W1Startdate Then
        Range("G" & i).EntireRow.Delete
        Next i
        MsgBox "task complete"
    Please use code tags when posting VBA Code in the forum. It makes for easier reading and is a forum standard.
    Aug 2011
    Thanks it is working!
    But it is taking huge amount of time when we delete larger data. i think it is deleting row by row.
    can we make change to delete the enter in one short now like deleting manually?
    Try
    Sub MYFILTER()
        Dim W1Startdate As String
        Dim dtFilter    As Date
        W1Startdate = Application.InputBox("Please Enter the Start Data in DD/MM/YYYY format", Type:=2)
        If W1Startdate = "False" Then Exit Sub
        If IsNumeric(Replace(W1Startdate, "/", vbNullString)) Then
            dtFilter = DateSerial(Split(W1Startdate, "/")(2), Split(W1Startdate, "/")(1), Split(W1Startdate, "/")(0))
            Range("A2:T" & Range("A1").End(xlDown).Row).AutoFilter Field:=7, Criteria1:=">" & dtFilter
            Range("A3:T" & Range("A2").End(xlDown).Row).SpecialCells(12).EntireRow.Delete
            If ActiveSheet.AutoFilterMode Then ActiveSheet.AutoFilterMode = False
    Aug 2011
    No Sir,
    It is not deleting.
    Any error ? how many rows of data you have ?
    Aug 2011
    I found 2 issues:
    1.It is taking MM/DD/YYYY instead of DD/MM/YYYY.
    2. If the input dates between 1- 10 example 08/10/2014(10th Aug 2014) it is deleting correctly but the input dates between 11-31 example 08/15/2014 it is not taking any action.
    I have attached the data for your reference. Kindly help to correct the same.
    Regards,
    Prabhu
    It's working here. You need to enter the date in dd/mm/yyyy format.
  1. Delete Rows Based on Conditions
    By AbiG2009 in forum Excel Help
    Last Post: 12-26-2018, 01:24 PM
  2. search for data and delete rows containing it
    By RickStewart in forum Excel Help
    Last Post: 02-24-2014, 09:12 PM
  3. Delete blank rows
    By dhivya.enjoy in forum Excel Help
    Last Post: 10-23-2013, 10:04 PM
  4. Delete Rows
    Last Post: 12-13-2012, 11:48 AM
  5. Delete Empty Rows
    Last Post: 04-28-2011, 02:13 AM
