Thread: Grouping column containing Number values into specific subgroups
    i have a dynamic column with ageing number of Days listed, I am trying to Group these according to specific criteria
    i.e
    Less than 30 days
    31 to 45 Days
    46 to 70 Days
    71 to 99 Days
    >100 Days
    this criteria will remain Fixed throughout
    A pivot doesn't provide specific criteria as the group criteria are not fixed .. is there another method i could use to do this?
    Member p45cal's Avatar
    Oct 2013
    Quote Originally Posted by Sonny Thind View Post
    Less than 30 days
    31 to 45 Days
    46 to 70 Days
    71 to 99 Days
    >100 Days
    I've assumed:
    Less than 31 days
    31 to 45 Days
    46 to 70 Days
    71 to 99 Days
    >99 Days
    since 30 days and 100 days would not fit in any category. You'll have to tweak if I've guessed wrongly.
    Add a column with the formula in row 2:
    =INDEX({"<31";"31-45";"46-70";"71-99";">99"},MATCH(B2,{0;31;46;71;100},1))
    and copy down. Give the column a header, say Group.
    Then add a pivot table including this new column as part of its source data, include Group in the (top of the) Row Labels section of the pivot.
    See attached.
    I imagine there are more columns than you're showing in your real data; just add the columns you want to see to the Row Labels section of the pivot.
    hi p45cal
    . I really like the array formula.
    This really helps thank you very much for this..
  1. Replies: 3
    Last Post: 08-18-2013, 08:59 PM
  2. Replies: 6
    Last Post: 07-26-2013, 11:42 AM
  3. Replies: 8
    Last Post: 07-01-2013, 03:52 PM
  4. Replies: 10
  5. Converting a Column Number to a Column Letter
    Last Post: 12-17-2012, 02:29 AM
