Results 1 to 10 of 12
Thread: Split Upper / Lower case + concatenate rows
    Sep 2014
    I'm looking for a solution for several issues I have with a copied data set.
    The data set is as per column A and B in above screenshot.
    The problem in column A is that it contains the unique ID number but also shows blanks. It's not containing always the same number of blanks until the next ID number.
    (I have approx 4000 ID's in the dataset).
    The problem in Column B is that it contains both upper case and lower case characters. I have found on this forum several ways how to extract those, but my problem is that I need to concatenate all lower cases together. In the end I need 2 seperate columns:
    Column D may contain only the upper case characters from column B and has to concatenate those from multiple cells in the column within the ID range (column A).
    Column E is simular, but here I should concatenate all lower case characters from multiple cells in column B, within the ID range (column A).
    Who would be able to help me with this?
    Thanks !!!
    Member p45cal's Avatar
    Oct 2013
    Sep 2014
    Quote Originally Posted by p45cal View Post
    see attached.
    super, this looks what I want to see.
    I'm new with this, and run into following issue:
    I copied my real dataset into column A and B and also added an extra number on the bottom.
    Then I change this part of the formula (2 parts) to the last cell number in my dataset. but then I get following error message:
    "You cannot change part of an array"
    how can I solve this?
    Sub M_snb()
        ReDim sp(1 To Cells(1).CurrentRegion.Columns(1).SpecialCells(4).Areas.Count, 1 To 2)
        y = 1
        For Each ar In Cells(1).CurrentRegion.Columns(1).SpecialCells(4).Areas
            c00 = Join(Application.Transpose(ar.Offset(-1, 1).Resize(ar.Rows.Count + 1)))
            For j = 1 To Len(c00)
               If Mid(c00, j, 1) Like "[a-z]" Then
                    sp(y, 1) = Left(c00, j - 1)
                    sp(y, 2) = Mid(c00, j)
                    y = y + 1
                    Exit For
        Cells(20, 4).Resize(UBound(sp), UBound(sp, 2)) = sp
    Sep 2014
    Sub M_snb()
        y = 1
                    y = y + 1
                    Exit For
    thanks for the effort, but in my real data set I also have ID's without blank cells below and this code isn't picking those up.
    Oct 2013
    The arrays are only 2 cells wide. You select the two cells, adjust the formula, then ctrl+shift+Enter to enter the formula into both cells. Then you can copy the pair of cells down.
    Sep 2014
    thanks p45cal
    @snb, my appologies, I thought it didn't make a difference.
    apperently seen the other solution, it doesn't.
    Please do not quote !
    Why didn't you tell so in the first place ?
    It does; but you can only take it into account if the information doesn't lack.
    Sub M_snb()
        ReDim sp(1 To Cells(1).CurrentRegion.Columns(1).SpecialCells(2).Count, 1 To 2)
        y = 1
        For Each cl In Cells(1).CurrentRegion.Columns(1).Offset(1).SpecialCells(2)
            c00 = cl.Offset(, 1)
            If cl.Offset(1) = "" Then c00 = Join(Application.Transpose(cl.Offset(, 1).Resize(cl.Resize(UBound(sp)).SpecialCells(4).Areas(1).Cells.Count + 1)))
                    y = y + 1
                    Exit For
    Sep 2014
    @SNB got an error running this code. but got the other one working in this thread, so thanks for your efforts!
    @p45cal: thanks! it worked, you saved me a week of work!!!! much appreciated.
  1. Excel Macro to Split Multiple Columns into rows
    By cali-novice in forum Excel Help
    Last Post: 05-16-2014, 12:34 PM
  2. Replies: 6
    Last Post: 04-13-2014, 02:31 AM
  3. Random Time Between Fixed Lower And Upper Limits
    By papabill in forum Excel Help
    Last Post: 07-22-2013, 05:01 PM
  4. Replies: 4
    Last Post: 05-01-2013, 09:49 PM
  5. Reverse name in excel with upper case,edit formula
    By shrinivasmj in forum Excel Help
    Last Post: 09-11-2012, 01:31 PM
