Welcome to board.
You could try these methods.
Code:Option Explicit Sub kTest() Dim x, y, i As Long, c As Long Dim s1 As String, s2 As String s1 = "5, 45, 100, 113, 160" s2 = "2, 4, 45, 160, 189" x = Split(s1, ",") y = Split(s2, ",") With CreateObject("scripting.dictionary") .comparemode = 1 For i = 0 To UBound(x) If Len(Trim(x(i))) Then .Item(Trim(x(i))) = 1 End If Next For i = 0 To UBound(y) If .exists(Trim(y(i))) Then c = c + 1 End If Next MsgBox "There are " & c & " item(s) in common." End With c = 0 For i = 0 To UBound(y) If InStr(1, ", " & s1 & ", ", ", " & Trim(y(i)) & ", ", 1) Then 'careful about the delimiter c = c + 1 End If Next MsgBox "There are " & c & " item(s) in common." End Sub
