Results 1 to 8 of 8
Thread: Code to open up files in folder and sub-folder
    Apr 2012
    I Have the folowing code where I want to open up all files in a folder C:\pull as well as all the folders within C:\pull where the name contains ACCNTS(P). These are all XLS files
    See code below, which does nothing when acticated
    Sub Open_Files_Pull()
        Dim fso As Object 'FileSystemObject
        Dim fldStart As Object 'Folder
        Dim fld As Object 'Folder
        Dim fl As Object 'File
        Dim Mask As String
        Set fso = CreateObject("scripting.FileSystemObject") ' late binding
        'Set fso = New FileSystemObject 'or use early binding (also replace Object types)
        Set fldStart = fso.GetFolder("C:\Pull") ' <-- use your FileDialog code here
        Mask = "(p)*.xls"
        Debug.Print fldStart.Path & "\"
        ListFiles fldStart, Mask
        For Each fld In fldStart.SubFolders
            ListFiles fld, Mask
            ListFolders fld, Mask
    Sub ListFolders(fldStart As Object, Mask As String)
            Debug.Print fld.Path & "\"
            ListFiles fld, Mask
    Sub ListFiles(fld As Object, Mask As String)
        For Each fl In fld.Files
            If fl.Name Like Mask Then
                Debug.Print fld.Path & "\" & fl.Name
    Sub M_snb()
      c00="C:\Pull\" & replace(createobject(wscript.shell").exec("cmd /c Dir ""C:\Pull\*.xls"" /a/b").stdout.readall,vbcrlf,vbcrlf & "C:\Pull\") & vbcrlf
      sn=split(c00 & createobject(wscript.shell").exec("cmd /c Dir ""C:\Pull\*ACCNTS(P)*.xls"" /s/a/b").stdout.readall,vbcrlf)
       for j=0 to ubound(sn)
         msgbox sn(j)
       next
    End sub
    Apr 2012
    Thanks for the reply
    When running your code, I get "Compile Error: Syntax error" and the following code is highlighted
    Kindly test & amend code
    Why don't you ?
    Apr 2012
    Unfortunately, I don't understand your code
    I have tried to write my own code.
    If I copy the files from the sub-folders to C:\extract it works, but the code does not open the files containing the name ACCNTS (P) from the sub-folders
    It would be appreciated if you could amend my code as i'm battling to code the code sorted out to open these files in the sub-folders within C:\extract
     Sub Open_Files()
    Sheets("Workspace").Select
        Dim rngCell As Range
        Dim zFPath  As String
        Dim zFSpec  As String
         Dim Folder As String
        zFPath = "C:\extract\"
           Folder = Dir(zFPath, vbDirectory)
        For Each rngCell In Range("A1:A" & Cells(Rows.Count, 1).End(xlUp).Row)
           zFSpec = zFPath & Folder & rngCell.Value & ".xls"
           Workbooks.Open zFSpec
        Next rngCell
        Application.DisplayAlerts = True
    Jul 2012
    You should post a link to the other thread so other posters know what others have tried to help with
    list files in folder and sub-folder
    Open up workbooks in folder and sub-folders
    and here:
    Opening up files in folder and sub-folder | Windows Secrets Lounge
    Apr 2012
    My apologies-have read the link to Cross Posters and agree 100% with the sentiment. Will post solution on all the sites for once found, where I have cross posted
    My code is partly working.
  1. Replies: 2
    Last Post: 11-10-2013, 11:48 PM
  2. Replies: 15
    Last Post: 08-23-2013, 12:03 PM
  3. Replies: 0
    Last Post: 07-07-2013, 01:52 AM
  4. Replies: 1
    Last Post: 02-14-2013, 12:09 PM
  5. Open Folder Using VBA
    Last Post: 06-28-2011, 03:52 PM
