Results 1 to 7 of 7
Thread: Converting a Column Number to a Column Letter
    Apr 2011
    Astr = Split(Cells(1, Along).Address, "$")(1)
    Where
    Along = Column number to be converted to letter
    Astr = column letter returned
    xl2007 - Windows 7
    xl hates the 255 number
    Quote Originally Posted by Rasm View Post
    Where
    That code line looks awfully long to me. You can shorten your typing by an entire character if you do it this way ...
    Astr = Split(Columns(Along).Address, "$")(2)
    Junior Member Preeti Verma's Avatar
    May 2012
    'UDF to obtain column field for any cell(i,j)
    Function ColFld(ByVal num1 As Long, ByVal num2 As Long) As String
    Dim str As String, i As Long
    str = Replace(Cells(num1, num2).Address, "$", "")
    For i = 0 To 9
    str = Replace(str, CStr(i), "")
    Next i
    ColFld = str
    'UDF to obtain cell address field for any cell(i,j)
    Function CellFld(ByVal v1 As Long, ByVal v2 As Long) As String
    Dim st As String, j As Long
    For j = 0 To 9
    st = Replace(Cells(v1, v2).Address, "$", "")
    Next j
    CellFld= st
    'UDF to obtain row field for any cell(i,j)
    Function RowFld(ByVal num1 As Long, ByVal num2 As Long) As String
    For i = 65 To 90
    str = Replace(str, Chr(i), "")
    Next i
    RowFld = str
    Dec 2012
    When testing the code I have got an error
    Sub Test()
    MsgBox Astr
    Quote Originally Posted by KingTamo View Post
    Sub Test()
    MsgBox Astr
    Split returns an array of values, not a single value, so you have to specify which member of the array you want...
    MsgBox Astr(1)
    Dec 2012
    Thanks for reply
    But I have an error too when testing the code
    Sub Test()
    MsgBox Astr(1)
    Thanks for reply
    Sub Test()
    MsgBox Astr(1)
    Did you notice the explanation for "Along" from the first message (from where the code snippet came)? Namely...
    "Where
    Along = Column number to be converted to letter"
    The 1 inside the Cells call is the row and Along is a variable that should be assigned (or fully replaced by) a column letter.
  1. Replies: 10
  2. Replies: 7
    Last Post: 04-21-2013, 07:50 PM
  3. Replies: 11
    Last Post: 10-07-2012, 12:05 AM
  4. Replies: 1
    Last Post: 08-07-2012, 11:04 PM
  5. Replies: 3
