Results 1 to 6 of 6
Thread: Sum All Rows And Columns In A Range Where Criteria Matches Across Rows And Columns
    normonster, if the States and Brands do not repeat itself, then you can use this formula (in K2, based on the snapshot)
    =INDEX($B$2:$D$5,MATCH(I2,$A$2:$A$5,),MATCH(J2,$B$ 1:$D$1,))
    However, if the States and/or Brands are not unique, ie, if there are possibly the same State repeating itself as you go down the row, or Brands repeat itself across the columns, then you can use an array formula (again, in K2, according to the picture you posted)
    =SUM(IFERROR(N(INDIRECT(IF($A$2:$A$12=I2,"R"&ROW($ A$2:$A$12),0)&IF($B$1:$F$1=J2,"C"&COLUMN($B$1:$F$1 ),0),FALSE)),0))
    For a sample, please find attached a workbook using both the solutions
  1. Replies: 8
    Last Post: 04-20-2014, 10:15 PM
  2. seprate data in rows to columns
    By CORAL in forum Excel Help
    Last Post: 03-10-2014, 08:18 AM
  3. Replies: 6
    Last Post: 08-14-2013, 04:25 PM
  4. Move data from rows into columns for every unique value
    Last Post: 06-13-2013, 03:02 AM
  5. Hide and Unhide Rows and Columns
    Last Post: 05-11-2011, 12:00 AM
