Results 1 to 10 of 11
Thread: Get Combination Of Unique Values From N Columns Using Rand Or RandBetween Function
    Nov 2012
    I appreciate all the help I have gotten in the past, and I realize that I ask some of the dumbest questions, but I need help again.
    I have need of a formula using the random feature.
    I have columns, Entrees, Vegetables 1, Vegetables 2, and Starches. They have 10 items in each column.
    I need a formula that will choose one item from each column, and make sure that there are no duplicates (in the Vegetables column).
    I've been working on this what seems forever, but cannot figure it out.
    Can I get some help?
    Apr 2012
    Perhaps if you posted a sample spreadsheet of your data, it would be easier to supply you with a workable solution.
    Nov 2012
    How do I post a sample spreadsheet?
    Member p45cal's Avatar
    Oct 2013
    See attached, an unmanageable and grotesque formula, but it seems to work. There must be a better way. Would a user defined function be acceptable (a macro)?
    Oct 2013
    Quote Originally Posted by papabill View Post
    First click Reply or Reply with quote, then click Go Advanced and then click Manage Attachments and follow your nose.
    Nov 2012
    excel.xlsx
    Quote Originally Posted by alansidman View Post
    Oct 2013
    Why did you specifically refer to the vegetables column?!
    See attached.
    Nov 2012
    Quote Originally Posted by p45cal View Post
    Sorry, Originally the Veg1 and Veg2 columns were identical (until my brain figured out more vegetables) and I didn't want the same veg twice
    In line with p45cal, but a little more simpler approach maybe...
    Nov 2012
    The only thing that came through was a page (SHEET 2) of numbers, with "=RAND()" as the ONLY formula in each cell. Sorry, but nothing about it makes sense.
  1. Replies: 3
    Last Post: 07-29-2013, 09:15 AM
  2. Move data from rows into columns for every unique value
    Last Post: 06-13-2013, 03:02 AM
  3. List Unique Values Using Formula
    Last Post: 01-09-2012, 08:39 PM
  4. Replies: 2
    Last Post: 01-07-2012, 12:11 AM
  5. Lookup Multi-Column For Unique String Combination For Numeric Value Output
    Last Post: 07-03-2011, 07:23 PM
