Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Printing range of sheets in excel or in PDF
  1. #11
    Apr 2011
    Printing of range of sheets in excel or in PDF
    Hi, the short report is attached.
    excel_learner
    (Using XL 2007 & 2010)
    -------Learning never stops!
  2. #12
    For i = 3 To 38
        strRngName = .Cells(i, 2).Text
        If Not ThisWorkbook.Name = ActiveWorkbook.Name Then ThisWorkbook.Activate
        strShtname = Range(strRngName).Parent.Name
        strFileName = wbkActive.Path & "\" & strShtname & Format(Date, "dd-mm-yy")
        'clear any existing print areas and reset to named ranges areas
        With wbkActive.Worksheets(strShtname)
            .PageSetup.PrintArea = ""
            .PageSetup.PrintArea = .Range(strRngName).Address
            '// Paste the data to the workbook for PDF
            .Range(strRngName).Copy rngDest
            RowsCount = .Range(strRngName).Rows.Count
            Set rngDest = rngDest.Offset(RowsCount)
            '// Paste the data to a new workbook
            Set wbkNew = Workbooks.Add
            .Range(strRngName).Copy wbkNew.Worksheets(1).Range("a1")
            '// Save the print area as a new file
            wbkNew.SaveAs strFileName, 51
            wbkNew.Close
            Set wbkNew = Nothing
    Next i
  3. #13
    Apr 2011
    Hi, thank you it worked, creates the pdf file but looses print areas and original columns' width and formatting, does not convert the ranges into a separate page. It also create an excel file but with same issue of print areas.
    excel_learner
  4. #14
    code the copy paste part like this
    rngDest.PasteSpecial xlPasteValues
    rngDest.PasteSpecial xlPasteFormats
    rngDest.PasteSpecial xlPasteColumnWidths
  5. #15
    Apr 2011
    Thanks, however, in which place should i insert these codes.
    excel_learner
  6. #16
    Sorry.
    replace the following lines and paste the above code in procedure 'Print_Rangespdf'
  7. #17
    Apr 2011
    Hi, Admin, Thanks for the advice, however, see the attached file if i have correctly used the codes, as it has same formatting issue.
    Please advise and thank you for your cooperation and patience.
    Regards
    excel_learner
  8. #18
    Apr 2011
    Dears
    Any update on this.
    Thank you
    excel_learner
  9. #19
    Apr 2011
    Dears
    Any updates on this...please.
    excel_learner
  1. Replies: 3
    Last Post: 05-14-2013, 03:25 PM
    Last Post: 04-14-2013, 08:23 PM
  3. Print excel sheet to a PDF file
    By xander1981 in forum Excel Help
    Last Post: 12-14-2012, 02:16 PM
  4. Replies: 7
    Last Post: 08-08-2012, 10:24 AM
  5. Printing Sheets Based On Criteria VBA
    Last Post: 05-04-2011, 08:00 PM
