Results 1 to 6 of 6
Thread: InputBox OK and Cancel Button Problem
    Jul 2013
    Exclamation InputBox OK and Cancel Button Problem
    I have this macro code that can protect and unprotect, It will show the input box and ask for a password. my problem is when I choose cancel, it still protect the file, the same thing with my unprotect code. here is my code below
    Protect Code
    Sub ProtectAll()
        Dim wSheet          As Worksheet
         Dim Pwd             As String
        Pwd = InputBox("Enter your password to protect all worksheets", "Password Input")
         For Each wSheet In Worksheets
             wSheet.Protect Password:=Pwd
         Next wSheet
    UnProtect Code
    Sub UnProtectAll()
         Dim Pwd             As String
        Pwd = InputBox("Enter your password to unprotect all worksheets", "Password Input")
             wSheet.Unprotect Password:=Pwd
         Next wSheet
         If Err <> 0 Then
             MsgBox "You have entered an incorect password. All worksheets could not " & _
             "be unprotected.", vbCritical, "Incorect Password"
    Nov 2011
    Try this
    Sub ProtectAll()
         Dim Pwd             As String
        If Pwd <> "" Then
         Next wSheet
    Sub UnProtectAll()
         Dim Pwd             As String
         If Pwd <> "" Then
            Next wSheet
            If Err <> 0 Then
    Try this also:
    Sub ProtectAll()
        Dim Pwd             As String
        If Pwd = vbNullString Then GoTo ExitPoint
        Next wSheet
    ExitPoint:
        'Memory cleaning
        Set wSheet = Nothing
        Pwd = vbNullString
    Sub UnProtectAll()
        Dim Pwd             As String
        On Error GoTo ExitPoint
        Next wSheet
    ExitPoint:
        If Err <> 0 Then
            On Error GoTo -1: On Error GoTo 0: Err.Clear
        'Memory cleaning
        Pwd = vbNullString
    Jul 2012
    This is cross post
    You got the answer here but did not answer
    Moderator
    Jul 2012
    Dear mackypogi,
    As you can see cross-posting isn't very much appreciated. Read following link regarding this issue.
    http://www.excelfox.com/forum/f25/me...-posters-1172/
    Although this thread is effectively closed, I thought I would use it to introduce those reading it to my latest mini-blog article here which shows how to be able to react to the Cancel button in an VBA InputBox...
    How To React To The Cancel Button in a VB (not Application) InputBox
  1. Problem with line (row) in a macro
    By k0st4din in forum Excel Help
    Last Post: 03-19-2014, 07:59 AM
    Last Post: 11-02-2013, 04:17 PM
  3. Solve Block If Without End If Problem
    By jffryjsphbyn in forum Excel Help
    Last Post: 06-12-2013, 11:06 AM
  4. Replies: 8
    Last Post: 05-21-2013, 06:34 AM
  5. Print VBA cancel command not working
    By Tony in forum Excel Help
    Last Post: 02-07-2013, 07:09 PM
