Thread: Append Fields in an Existing ADO Recordset
    May 2012
    hi,
    I am using an ADO recordset in Excel to grab a huge CSV (~1 million rows) and use it as External data to create a PivotCache & Pivottable.
    I want to edit the recordset to append additional fields (columns) and add data that is calculated from one of the fields viz a week field which has string data like this:
    e.g. if A, B, C are the recordset fields,
    A B C D E
    w 2011 01 01 2011
    w 2011 02 02 2011
    w 2011 03 03 2011
    w 2011 04 04 2011
    w 2012 05 05 2012
    then I want to append fields D, E and add data to them as shown above, stripped from column A like I would do in excel,
    D = VALUE(RIGHT(A2,2))
    E = VALUE(MID(A2,3,4))
    but I want to do using SQL functions.
    then I use this appended recordset to create a pivotcache and a pivottable using it as an external datasource.
    SEE MY COMMENTS IN THE CODE.
    PHP Code:
    Option Explicit
    Sub GetCSV
    Application.EnableEvents False
    Application
    .DisplayAlerts False
    Application
    .ScreenUpdating False
    Dim sFileName
    As String
    Dim sFilePath
    As String
    Dim rngPivotDest
    As Range
    Dim pcPivotCache
    As PivotCache
    Dim ptPivotTable
    As PivotTable
    Dim SQL
    As String
    Dim sConnStrP1
    As String
    Dim sConnStrP2
    As String
    Dim cConnection
    As Object
    Dim rsRecordset
    As ObjectRS As ObjectFld As Object
    Dim Sht
    As Worksheet
    Dim Conn
    As Object
    With ThisWorkbook
    Set rsRecordset
    CreateObject("ADODB.Recordset")
    Set RS CreateObject("ADODB.Recordset")
    Set cConnection CreateObject("ADODB.Connection")
    sFileName Application.GetOpenFilename("Text Files, *.asc; *.txt; *.csv"1"Select a Text File", , False)
    sFilePath Left(sFileNameInStrRev(sFileName"\"))
    sFileName = Replace(sFileName, sFilePath, "")
    sConnStrP1 = "
    Driver={Microsoft Text Driver (*.txt; *.csv)};Dbq="
    sConnStrP2 = "
    ;Extensions=asc,csv,tab,txt;FIL=text;Persist Security Info=False"
    cConnection.Open sConnStrP1 & sFilePath & sConnStrP2
    SQL = "
    SELECT FROM [" & sFileName & "]"
    Set rsRecordset = cConnection.Execute(SQL)
    '****** THIS ENTIRE PART IS NOT WORKING******
    With RS
        .cursorlocation = 3 'aduseclient
        .cursortype = 2 'adOpenDynamic 3 'adopenstatic
    '    For Each Fld In rsRecordset.Fields
    '        .Fields.append Fld.Name, Fld.Type, Fld.definedsize, Fld.Attributes, Fld.adFldIsNullable
    '    Next Fld
        .locktype = 4 'adLockBatchOptimistic'3 'adlockoptimistic
        .Fields.append "
    WeekNumber", 3 'adinteger
        .Fields.append "
    Year", 7 'addate
        .Open
        .Update
    'do something to grab the entire data into RS
    Set RS = rsRecordset.Clone
    'or something like
    Set RS = rsRecordset.getrows
    'append some function code to the last 2 fields to strip YEAR & WEEK from 1st field.
    End With
    'Delete any connections in workbook
    On Error Resume Next
    For Each Conn In .Connections
        Conn.Delete
    Next Conn
    On Error GoTo 0
    'Delete the Pivot Sheet
    For Each Sht In .Sheets
        If LCase(Trim(Sht.Name)) = LCase("
    Pivot") Then Sht.Delete
    Next Sht
    On Error GoTo 0
    'Create a PivotCache
    Set pcPivotCache = .PivotCaches.Create(SourceType:=xlExternal)
    Set pcPivotCache.Recordset = rsRecordset
    'Create a Pivot Sheet
    .Sheets.Add after:=.Sheets("
    Main")
    ActiveSheet.Name = "
    Pivot"
    'Create a PivotTable
    Set ptPivotTable = pcPivotCache.CreatePivotTable(TableDestination:=.Sheets("
    Pivot").Range("A3"))
    With ptPivotTable
        .Name = "
    PivotTable"
        .SaveData = False
    End With
    With ptPivotTable
        With .PivotFields("
    Level")
        .Orientation = xlPageField
        .Position = 1
        End With
        With .PivotFields("
    Cat")
        .Position = 1
        End With
        With .PivotFields("
    Mfgr")
        .Position = 1
        End With
        With .PivotFields("
    Brand")
        .Position = 1
        End With
        With .PivotFields("
    Descr")
        .Orientation = xlRowField
        .Position = 1
        End With
    End With
    ptPivotTable.AddDataField ptPivotTable.PivotFields("
    Sales Value from CrossCountrySales"), "Sum of Sales Value from CrossCountrySales", xlSum
    With ptPivotTable.PivotFields("
    Week")
        .Orientation = xlColumnField
        .Position = 1
    End With
    Sum of Sales Value from CrossCountrySales")
        .Calculation = xlNoAdditionalCalculation
    End With
    cConnection.Close
    Set rsRecordset = Nothing
    Set cConnection = Nothing
    Set Conn = Nothing
    End With
    Application.ScreenUpdating = True
    Application.DisplayAlerts = True
    Application.EnableEvents = True
    End Sub
    Last edited by Junoon; 05-22-2014 at 11:10 PM. Reason: http://www.utteraccess.com/forum/Append-Fields-Existin-t2018243.html
    You can not append a new blank field in the same recordset but there is a workaround for this:
    1. First get all data in one recordset which is Recordset1
    2. Then create a new recordset Recordset2 and add all existing field form Recordset1
    3. Add new field in Recordset2
    4. Add data from Recordset1 to Recordset2
    strSql = "Select Column1, Column2 from Table1"
    With rs
        .Open strSql, Con, adOpenForwardOnly, adLockBatchOptimistic
    rscp.Fields.Append "Column1", adVarChar, 6
    rscp.Fields.Append "Column2", adVarChar, 6
    rscp.Fields.Append "Column3", adVarChar, 50 'New Column
    rscp.Open
    For i = 1 To rs.RecordCount
        rscp.AddNew _
        Array("Column1", "Column2", "Column3"), _
        Array(rs.Fields(0).Value, rs.Fields(1).Value, Null)
        rs.MoveNext
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314619#p314619
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314600#p314600
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314599#p314599
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314274#p314274
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314229#p314229
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314195#p314195
    https://www.eileenslounge.com/viewtopic.php?f=36&t=39706&p=314110#p314110
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314081#p314081
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314078#p314078
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=314062#p314062
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314054#p314054
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313971#p313971
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313909#p313909
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40574&p=313879#p313879
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313859#p313859
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313855#p313855
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313848#p313848
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313843#p313843
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313792#p313792
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313771#p313771
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313767#p313767
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313746#p313746
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313744#p313744
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40560&p=313741#p313741
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313622#p313622
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313575#p313575
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313573#p313573
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313563#p313563
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313555#p313555
    https://www.eileenslounge.com/viewtopic.php?f=39&t=40265&p=313468#p313468
    https://www.eileenslounge.com/viewtopic.php?f=42&t=40505&p=313411#p313411
    https://www.eileenslounge.com/viewtopic.php?f=32&t=40473&p=313384#p313384
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313382#p313382
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313380#p313380
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40501&p=313378#p313378
    https://www.eileenslounge.com/viewtopic.php?f=32&t=40473&p=313305#p313305
    Member Transformer's Avatar
    Mar 2012
    Regards,
    Transformer
  1. Export data from Excel to Access Table (ADO) using VBA
    Last Post: 02-24-2015, 07:53 PM
  2. Replies: 7
    Last Post: 04-04-2014, 03:16 PM
  3. VBA Trick of the Week: Range to Recordset Without Making Connection
    Last Post: 07-11-2013, 06:21 PM
  4. Split Closed Workbook into Multiple Workbooks Using ADO
    Last Post: 10-02-2011, 08:34 PM
  5. Replies: 9
    Last Post: 09-09-2011, 02:30 AM
