Results 1 to 7 of 7
Thread: Formula To Sum From Movement To Cummulative Total
    Apr 2011
    Question Formula To Sum From Movement To Cummulative Total
    I want the movement figures in one table to sum at cummulative level and stop if all values are summed up at last year, i have attached an example to formula and output required.
    Kindly assist.
    excel_learner
    (Using XL 2007 & 2010)
    -------Learning never stops!
    Member p45cal's Avatar
    Oct 2013
    Spreadsheet Formulas:
    Cell Formula
    C15 =IF(C4=0,0,SUM($C4:C4))
    K15 =SUM(C4:J4)
    C15 filled across to J15, then filled down
    K15 filled down
    Apr 2011
    Thanks much.
    excel_learner
    Apr 2011
    Dear I have observed a small issue with the formula that, if in movement any year value is 0 then it does not accumulate for upto that year. I have attached an example highlighting the same.
    Kindly see.
    excel_learner
    Oct 2013
    Your example file, in cell E4, rather than showing a 0 (zero), is actually blank/empty. Curiously, cells I4 anf J4 contain 0s (zeroes) although you have those zeroes appearing as dashes.
    The difficulty lies when we encounter a cell such as G6; Is this cell showing 0 for 2013 because that year had no movement, or is there simply no value for that year? Your answer determines whether there should be a value appearing in G17 or not of your most recent file.
    Personally, I think it confusing that there should be 0 values in a cell such as I7, and years with no movement are plain blank (D7).
    Reply with how you really want the values in those cells to be and I will provide a formula.
    There is a much more complicated formula that I could give but I don't think you or I want to go down that route.
    If you reply as I expect, then the formula will be:
    =IF(ISBLANK(C4),"",SUM($C4:C4))
    Apr 2011
    Thanks, i would say it will be either blank or 0 (as it comes from another formula) saying that there was no movement in that year, but it in cumulative table should add up with last year i.e the cumulative total should remain same as last year for the year where no movement is reported. The example i have attached in "Output required" this is what is required.
    see if this helps.
    excel_learner
    Oct 2013
    Quote Originally Posted by excel_learner View Post
    in which case what you ask is impossible as there is no way to differentiate between a blank or zero being a 0 being after a final year or a blank or zero being a zero value year with more years to come perhaps
    This had already been established and is no further help.
  1. no color in rows which have the Total or Grand Total
    Last Post: 09-16-2013, 05:24 AM
  2. Excel Sum Formula
    By mfaisalrazzak in forum Excel Help
    Last Post: 07-26-2013, 11:42 AM
  3. Sum Of The Digits In A Cell Using Formula
    By venkat1926 in forum Excel Help
    Last Post: 04-30-2013, 07:11 PM
  4. Enter SUM SUMIFS Formula Using VBA
    By Rick in forum Excel Help
    Last Post: 02-23-2013, 07:32 PM
  5. Sum Ifs Formula needed with Max Date range
    By trankim in forum Excel Help
    Last Post: 09-19-2012, 09:50 AM
