Results 1 to 9 of 9
Thread: VBA To Extract Latest X Number Of Rows From A Range and Paste To Another
    Apr 2014
    I have a range of data from A1:F5000, what is the code to extract the last/newest 500 rows of the data and paste into H:M
    Jan 2012
    You could try this
    Range("A" & Rows.Count).End(xlUp)(-498).Resize(500,6).Copy Range(H1")
    Apr 2014
    the code shows an error when the no. of rows in the range is lesser than 500 rows, how to correct it, thank you
    Why don't you try to come up with a solution yourself ?
    The basic ingredients have been provided to you.
    If you read the code and analyse it it's not complicated.
    Apr 2014
    problem solved, thank you
    mrprofit, for posterity, it would be great if you could share your solution. Here's my solution
        With Range("A" & Rows.Count).End(xlUp)
            .Cells(Application.Max(-498, 2 - .Row)).Resize(Application.Min(500, .Row), 6).Copy Range("H1")
    Apr 2014
    My solution,
    If Sheets("Sheet1").Cells(Rows.Count, 2).End(xlUp).Row >= 500 Then
           Range("A" & Rows.Count).End(xlUp)(-498).Resize(500, 6).Select
     Range("A1:F500").Select
    End IF
    Sub M_snb()
        Range("A1:F500").Offset(Abs((Columns(1).SpecialCells(2).Count > 500)) * Columns(1).SpecialCells(2).Count).copy cells(1,8)
    This single code line should also work...
    Cells(Application.Max(1, Cells(Rows.Count, "A").End(xlUp).Row - 499), "A").Resize(500, 6).Copy Range("H1")
    Last edited by bakerman; 04-14-2014 at 05:22 AM. Reason: Code tags added for readability
  1. Copy/Paste Excel Range/Chart into Powerpoint VBA
    Last Post: 03-13-2014, 02:59 PM
    Last Post: 03-08-2014, 02:49 AM
    Last Post: 02-12-2014, 10:47 AM
  4. VBA To Extract Certain Rows From A Text File
    By Bogdan in forum Excel Help
    Last Post: 08-31-2013, 06:57 PM
  5. Macro Copy Columns and Paste in rows.
    By TommyKris in forum Excel Help
    Last Post: 03-06-2013, 02:36 PM
