Results 1 to 10 of 15
Thread: VBA Code Breaks During Runtime But Not In Debug Mode
    Hello,
    I think I am doing something stupid but can't figure out what. go to the code file and run the code there are not issues at all. I run the code from the workbook form and there are random errors???
    I suspect this must be down to a setting on TOOLS>Options but I can't think what.
    to clarrify, I have a workbook that pops up with a userform on OPEN event, from the form the user can produce various reports. All works fine when the form us run from code file but if user opens the workbook and continues from the userform there are lots of debug errors. This only happens on my machine also which leads me to think its my specific excel settings.
    Any help would be very happily received. Thanks.
    xander1981, go to the VBA editor, and compile the VBA project. Exit Excel, and then after restarting your computer, open the workbook again.
    In addition, here are some suggestions on Module breaks with no breakpoint added - Microsoft Access / VBA
    Thanks Excel Fox but that didnt work. Here is my code, It breaks on line "ActiveSheet.Range("A10000").End(xlUp).Offset(1).S elect"
    If Me.oComment.Value = "" Then
    MsgBox ("Please write your comment or cancel"), vbOKOnly, "Missing info"
    Dim oAlexJ As String, AlexTwo As String
    oAlexJ = Pass"
    oAlexTwo = "word"
    Workbooks.Open FileName:="c:\Felixstowe\Employee Opinion Database.xlsx", ReadOnly:=False, Password:=oAlexJ & AlexTwo, ignorereadonlyrecommended:=True
    ActiveSheet.Range("A10000").End(xlUp).Offset(1).Select
    Selection.Value = Me.oComment.Value
    ActiveCell.Offset(0, 1).Value = Date
    Workbooks("Employee Opinion Database.xlsx").Save
    Workbooks("Employee Opinion Database.xlsx").Close
    Unload Opinion
    Workbooks("Employee Opinion Send.xlsm").Close
    Can you check if the worksheet is protected?
    No, not protected. I have compiled the project with no errors and option explicit is now set on each form that runs code. So strange it works fine when run from code page but not form. I also notice that 'WITH' statements don't work now if thats any clue to the problem. The code runs from a Macro enabled workbook and opens various .xls workbooks.
    https://stackoverflow.com/questions/33868233/shell-namespace-not-accepting-string-variable-but-accepting-string-itself/77888851#77888851
    http://www.eileenslounge.com/viewtopic.php?p=322084#p322084
    http://www.eileenslounge.com/viewtopic.php?p=321822#p321822
    http://www.eileenslounge.com/viewtopic.php?p=322424#p322424
    here is all the code in the form,
    Private Sub oCancel_Click()
    ActiveWorkbook.Saved = True
    ActiveWorkbook.Close
    Private Sub oSend_Click()
    Dim oAlexJ As String, oAlexTwo As String
    oAlexJ = "Pass"
    oAlexTwo = "word"
    Workbooks.Open FileName:="c:\\DGF Felixstowe\Employee Opinion Database.xlsx", ReadOnly:=False, Password:=oAlexJ & oAlexTwo, ignorereadonlyrecommended:=True
    Unload Opinion
    Me.BackColor = RGB(255, 192, 0)
    Me.oSend.BackColor = RGB(255, 192, 0)
    Me.oSend.ForeColor = RGB(153, 0, 51)
    Me.oCancel.BackColor = RGB(255, 192, 0)
    Me.oCancel.ForeColor = RGB(153, 0, 51)
    Look into the vbeditor/ special/references. You'll find probably some missing.
    Did you try to run the workbook from another computer?
    Thanks snb yes I thought of that also but don't think my library is missing anything. Excel Fox - Yes and there are no issues so i think its specific to me excel settings.
  1. Did You Know :: Bullet Points & Line Breaks in Excel Cells
    Last Post: 06-11-2013, 01:55 PM
  2. Combobox Not Working In Excel Workbook Shared Mode
    Last Post: 06-03-2013, 01:25 PM
  3. Changing Slideshow viewing mode to kiosk using vba
    By Times in forum Powerpoint Help
    Last Post: 05-10-2013, 12:37 AM
  4. Runtime Error 481 invalid figure when PNG
    By Tony in forum Excel Help
    Last Post: 02-12-2013, 12:59 AM
  5. VBA Code Works Only in debug Mode.
    Last Post: 06-17-2012, 06:14 AM
