Hi everyone, I am trying to write a macro in which I get prompted to browse for 2 files and then, to extract specific (fixed) ranges and them compare them for differences. I know it should be easy but it has been a while since I used VBA. The code I have so far is the following, but it is creating many duplicates. Please amend or kindly write me a new code
Code:Sub HowardC() Dim AllCells As Range Dim cell As Range, Rng As Range Dim lrow As Long, Rlrow As Long Dim Myval As Integer Dim Item As Variant Dim wb As Workbook With Application.FileDialog(msoFileDialogOpen) .InitialFileName = "C:\" & ThisWorkbook.Path ' Default path .FilterIndex = 3 .Title = "Please Select a File" .ButtonName = "Open" .AllowMultiSelect = False .Show If .SelectedItems.Count = 0 Then Exit Sub ' User clicked cancel Set wb = Workbooks.Open(FileName:=.SelectedItems(1)) End With lrow = ActiveSheet.Range("a1").End(xlUp).Row Set AllCells = Range("A1:A" & lrow) For Each Item In AllCells Range("D1:E1").Select '' E-H Selection.AutoFilter With Selection .AutoFilter Field:=2, Criteria1:=Item '' this set the filtered data for the value End With Set Rng = ActiveSheet.AutoFilter.Range Rlrow = ThisWorkbook.Sheets("TBTXT2").Range("C65536").End(xlUp).Row + 1 Rng.Offset(1, 1).Resize(Rng.Rows.Count - 1, 4).Copy Destination:=ThisWorkbook.Sheets("TBTXT2").Cells(Rlrow, 2) Next Item Selection.AutoFilter ActiveWorkbook.Close False End Sub
Thanks a lot
