It is easily understood from my post above that you should REPLACE one line with another.
Code:Sub ToggleProperties(ByVal ShowRowColHeads As Boolean, _ ByVal ShowSheetTab As Boolean, _ ByVal ShowGridLines As Boolean, _ ByVal DisplayFBar As Boolean, _ ByVal DisplayRibbon As Boolean, _ ParamArray ShtNames() As Variant) If Not IsMissing(ShtNames) Then ThisWorkbook.Worksheets(ShtNames).Select ActiveWindow.DisplayHeadings = ShowRowColHeads ActiveWindow.DisplayWorkbookTabs = ShowSheetTab ActiveWindow.DisplayGridlines = ShowGridLines Application.DisplayFormulaBar = DisplayFBar Application.ExecuteExcel4Macro "SHOW.TOOLBAR(""Ribbon""," & DisplayRibbon & ")" ThisWorkbook.Worksheets(ShtNames(0)).Select End If End Sub
