Thread: Macro to pull data ranges and comapre them
    Mar 2014
    Hi everyone, I am trying to write a macro in which I get prompted to browse for 2 files and then, to extract specific (fixed) ranges and them compare them for differences. I know it should be easy but it has been a while since I used VBA. The code I have so far is the following, but it is creating many duplicates. Please amend or kindly write me a new code
    Sub HowardC()
    Dim AllCells As Range
    Dim cell As Range, Rng As Range
    Dim lrow As Long, Rlrow As Long
    Dim Myval As Integer
    Dim Item As Variant
    Dim wb As Workbook
        With Application.FileDialog(msoFileDialogOpen)
            .InitialFileName = "C:\" & ThisWorkbook.Path            ' Default path
            .FilterIndex = 3
            .Title = "Please Select a File"
            .ButtonName = "Open"
            .AllowMultiSelect = False
            .Show
            If .SelectedItems.Count = 0 Then Exit Sub   ' User clicked cancel
            Set wb = Workbooks.Open(FileName:=.SelectedItems(1))
        lrow = ActiveSheet.Range("a1").End(xlUp).Row
        Set AllCells = Range("A1:A" & lrow)
        For Each Item In AllCells
        Range("D1:E1").Select     '' E-H
            Selection.AutoFilter
            With Selection
                .AutoFilter Field:=2, Criteria1:=Item '' this set the filtered data for the value
                Set Rng = ActiveSheet.AutoFilter.Range
                    Rlrow = ThisWorkbook.Sheets("TBTXT2").Range("C65536").End(xlUp).Row + 1
                    Rng.Offset(1, 1).Resize(Rng.Rows.Count - 1, 4).Copy Destination:=ThisWorkbook.Sheets("TBTXT2").Cells(Rlrow, 2)
        Next Item
    ActiveWorkbook.Close False
    Thanks a lot
    Last edited by bakerman; 03-26-2014 at 04:04 AM. Reason: Code tags added for readability
    Moderator
    Jul 2012
    Some remarks.
    lRow always result in 1 since A1 is top row.
    AllCells always result in 1 cell value being A1 value.
    Autofilter will therefore filter on 1 value only and the For...Next loop has no added value.
    Avoid using Select and Selection in code because this is really unnecessary. Instead use With...End With statement.
    Mar 2014
    Many thanks for your reply. Are you able to write up a quick code to entirly replace this code, as I think I am stuck here. I just need to pull specific data ranges from 2 files that I will browse for, and then I will use the excel compare features. so I just need the code to broswse and pull specific (fixed) data ranges from the browsed for files. Your help is much appreciated.
  1. Replies: 11
    Last Post: 09-30-2013, 03:40 PM
  3. Replies: 2
    Last Post: 04-26-2013, 04:59 PM
  4. IE Automated Login/Table Pull
    By mrmmickle1 in forum Hire A Developer
    Last Post: 04-04-2013, 04:58 PM
  5. Replies: 3
    Last Post: 05-14-2012, 11:30 AM
