I've written a program which looks up a value which the user inputs together with the different option the user choose, I have to lookup this input value at different columns worksheets and return the values accordingly. Everything works fine until I add in the VLookup line. I get a RunTime Error 9 Subscript Out of RangeI've tried using a For Next loop instead of the VLookup but it gave an error too. Hopefully I've explained myself clearly.
Here's the code:
Code:Private Sub UserForm_Initialize() SingleACText.Text = 230 ThreeACText.Text = 400 CaSCText.Text = "Table" CaOLText.Text = "Table" CgText.Text = "Table" CiText.Text = 0.5 ' Call SetBackColor(DataTable.TabIndex(0), vbLightOrange) ' Call SetBackColor(DataTable.TabIndex(1), vbSkyBlue) ' Call SetBackColor(DataTable.TabIndex(2), vbYellow) ' Call SetBackColor(DataTable.TabIndex(3), vbGold) DataTable.ViewOnlyMode = True DataTable.Cells.Clear Worksheets("Ca").Range("A1:D19").Copy DataTable.Range("A1:D19").Paste DataTable.Selection.EntireColumn.AutoFit DataTable.Range("B7").Select DataTable.ActiveWindow.FreezePanes = True DataTable.Range("A1").Select End Sub Private Sub Tables_Change() Dim n As Integer DataTable.ViewOnlyMode = True n = Tables.SelectedItem.Index ' Call SetBackColor(MultiPage1.Pages(0), vbYellow) 'Yellow. ' Call SetBackColor(MultiPage1.Pages(1), RGB(255, 0, 0)) 'Red. ' Call SetBackColor(MultiPage2.Pages(0), vbGreen) 'Green. ' Call SetBackColor(MultiPage2.Pages(1), vbMagenta) 'Purple. Select Case n Case 0 DataTable.Cells.Clear Worksheets("Ca").Range("A1:D19").Copy DataTable.Range("A1:D19").Paste DataTable.Selection.EntireColumn.AutoFit DataTable.Range("B7").Select DataTable.ActiveWindow.FreezePanes = True DataTable.Range("A1").Select Case 1 DataTable.Cells.Clear Worksheets("Ca").Range("E1:H19").Copy DataTable.Range("A1:D19").Paste DataTable.Selection.EntireColumn.AutoFit DataTable.Range("B7").Select DataTable.ActiveWindow.FreezePanes = True DataTable.Range("A1").Select Case 2 DataTable.Cells.Clear Worksheets("Cg").Range("A1:I24").Copy DataTable.Range("A1:I24").Paste DataTable.Selection.EntireColumn.AutoFit DataTable.Range("B7").Select DataTable.ActiveWindow.FreezePanes = True DataTable.Range("A1").Select Case 3 DataTable.Cells.Clear Worksheets("ISO-AWG").Range("A1:C36").Copy DataTable.Range("A1:C36").Paste DataTable.Selection.EntireColumn.AutoFit DataTable.Range("6:6").Select DataTable.ActiveWindow.FreezePanes = True DataTable.Range("A1").Select End Select End Sub Private Sub ReturnCableLengthText_Change() ReturnCableLengthSpin.Value = Val(ReturnCableLengthText.Text) End Sub Private Sub ReturnCableLengthSpin_Change() ReturnCableLengthText.Text = ReturnCableLengthSpin.Value End Sub Private Sub LoadCurrentText_Change() LoadCurrentSpin.Value = Val(LoadCurrentText.Text) End Sub Private Sub LoadCurrentSpin_Change() LoadCurrentText.Text = LoadCurrentSpin.Value End Sub Private Sub OverloadCurrentText_Change() OverloadCurrentSpin.Value = Val(OverloadCurrentText.Text) End Sub Private Sub OverloadCurrentSpin_Change() OverloadCurrentText.Text = OverloadCurrentSpin.Value End Sub Private Sub CgText_Change() CgSpin.Value = Val(CgText.Text) * 100 End Sub Private Sub CgSpin_Change() CgText.Text = CgSpin.Value * 0.01 End Sub Private Sub CiText_Change() CiSpin.Value = Val(CiText.Text) * 100 End Sub Private Sub CiSpin_Change() CiText.Text = CiSpin.Value * 0.01 End Sub Private Sub Armoured_Change() Select Case Armoured.Value Case True: SingleCore.Enabled = False Case False: SingleCore.Enabled = True End Select End Sub Private Sub NonMagneticArmour_Change() Select Case NonMagneticArmour.Value Case True: MultiCore.Enabled = False Case False: MultiCore.Enabled = True End Select End Sub 'Private Sub SingleCore_Change() ' Select Case SingleCore.Value ' Case True: Armoured.Enabled = False ' Case False: Armoured.Enabled = True ' End Select 'End Sub 'Private Sub MultiCore_Change() ' Select Case MultiCore.Value ' Case True: NonMagneticArmour.Enabled = False ' Case False: NonMagneticArmour.Enabled = True ' End Select 'End Sub Private Sub TwoCoresCables_Change() Select Case TwoCoresCables.Value Case True: ThreeAC.Enabled = False Case False: ThreeAC.Enabled = True End Select End Sub Private Sub ThreeFourCoresCables_Change() Select Case ThreeFourCoresCables.Value Case True: DC.Enabled = False SingleAC.Enabled = False Case False: DC.Enabled = True SingleAC.Enabled = True End Select End Sub 'Private Sub DC_Change() ' Select Case DC.Value ' Case True: OneTrefoil.Enabled = False ' ElevenTrefoil.Enabled = False ' TwelveTrefoil.Enabled = False ' Case False: OneTrefoil.Enabled = True ' ElevenTrefoil.Enabled = True ' TwelveTrefoil.Enabled = True ' End Select 'End Sub 'Private Sub DC_Change() ' Select Case DC.Value ' Case True: ThreeFourCoresCables.Enabled = False ' Case False: ThreeFourCoresCables.Enabled = True ' End Select 'End Sub 'Private Sub SingleAC_Change() ' Select Case SingleAC.Value ' Case True: ThreeFourCoresCables.Enabled = False ' Case False: ThreeFourCoresCables.Enabled = True ' End Select 'End Sub 'Private Sub ThreeAC_Change() ' Select Case ThreeAC.Value ' Case True: TwoCoresCables.Enabled = Fasle ' Case False: Two CoresCables.Enabled = True ' End Select 'End Sub Private Sub Method1_Change() Select Case Method1.Value Case True: Select Case ThreeAC.Value Case True: OneTrefoil.Enabled = True Case False: OneTrefoil.Enabled = False End Select Case False: OneTrefoil.Enabled = False End Select End Sub Private Sub Method11_Change() Select Case Method11.Value Case True: Select Case ThreeAC.Value Case True: ElevenTrefoil.Enabled = True Case False: ElevenTrefoil.Enabled = False End Select Case False: ElevenTrefoil.Enabled = False End Select End Sub Private Sub Method12_Change() Select Case Method12.Value Case True: Select Case ThreeAC.Value Case True: TwelveTrefoil.Enabled = True Case False: TwelveTrefoil.Enabled = False End Select Horizontal.Enabled = True Vertical.Enabled = True Case False: TwelveTrefoil.Enabled = False Horizontal.Enabled = False Vertical.Enabled = False End Select End Sub Private Sub TwelveTrefoil_Change() Select Case TwelveTrefoil.Value Case True: Horizontal.Enabled = False Vertical.Enabled = False Case False: Horizontal.Enabled = True Vertical.Enabled = True End Select End Sub Private Sub Horizontal_Change() Select Case Horizontal.Value Case True: TwelveTrefoil.Enabled = False Case False: TwelveTrefoil.Enabled = True End Select End Sub Private Sub Vertical_Change() Select Case Vertical.Value Case True: TwelveTrefoil.Enabled = False Case False: TwelveTrefoil.Enabled = True End Select End Sub Private Sub OKButton_Click() Dim Msg As String Dim Ct As Single ' Dim WorksheetName As String ' Dim WorksheetNumber As Integer 'Display Messages If Aluminium Then Msg = Msg & Aluminium.Caption If Copper Then Msg = Msg & Copper.Caption If PVC Then Msg = Msg & " " & PVC.Caption If PVC Then WorksheetName = "DataPVC" 'If Rubber Then Msg = Msg & vbNewLine & Rubber.Caption If Thermosetting Then Msg = Msg & " " & Thermosetting.Caption If Thermosetting Then WorksheetName = "DataThermo" If Armoured Then Msg = Msg & vbNewLine & Armoured.Caption If Armoured Then WorksheetNumber = "3" If NonArmoured Then Msg = Msg & vbNewLine & NonArmoured.Caption If NonArmoured Then WorksheetNumber = "1" If NonMagneticArmour Then Msg = Msg & vbNewLine & NonMagneticArmour.Caption If NonMagneticArmour Then WorksheetNumber = "3" If Method1 Then Msg = Msg & " " & Method1.Caption If Method3 Then Msg = Msg & " " & Method3.Caption If Method4 Then Msg = Msg & " " & Method4.Caption If Method11 Then Msg = Msg & " " & Method11.Caption If Method12 Then Msg = Msg & " " & Method12.Caption If Method13 Then Msg = Msg & " " & Method13.Caption If OneTrefoil Then Msg = Msg & " " & OneTrefoil.Caption If ElevenTrefoil Then Msg = Msg & " " & ElevenTrefoil.Caption If TwelveTrefoil Then Msg = Msg & " " & TwelveTrefoil.Caption If Horizontal Then Msg = Msg & " " & Horizontal.Caption If Vertical Then Msg = Msg & " " & Vertical.Caption If MultiCore Then WorksheetNumber = WorksheetNumber + 1 If SingleCore Then WorksheetNumber = WorksheetNumber + 0 WorksheetName = WorksheetName & WorksheetNumber If TwoCoresCables Then Select Case MultiCore.Value Case True: Msg = Msg & vbNewLine & "2 Core - " & MultiCore.Caption & " Cables" Case False: Select Case SingleCore.Value Case True: Msg = Msg & vbNewLine & "2 " & SingleCore.Caption & " Cables" Case False: Msg = Msg End Select End Select End If If ThreeFourCoresCables Then Select Case MultiCore.Value Case True: Msg = Msg & vbNewLine & "3/4 Core - " & MultiCore.Caption & " Cables" Case False: Select Case SingleCore.Value Case True: Msg = Msg & vbNewLine & "3/4 " & SingleCore.Caption & " Cables" Case False: Msg = Msg End Select End Select End If If DC Then Msg = Msg & vbNewLine & DC.Caption & " " & DCText.Text & "V" If SingleAC Then Msg = Msg & vbNewLine & SingleAC.Caption & " " & SingleACText.Text & "V" If ThreeAC Then Msg = Msg & vbNewLine & ThreeAC.Caption & " " & ThreeACText.Text & "V" Msg = Msg & vbNewLine If ReturnCableLengthText.Text = Empty Then ReturnCableLengthText.Text = "0" Msg = Msg & vbNewLine & "Return Cable Length: " & ReturnCableLengthText.Text & " m" If LoadCurrentText.Text = Empty Then LoadCurrentText.Text = "0" Msg = Msg & vbNewLine & "Load Current: " & LoadCurrentText.Text & " A" If OverloadCurrentText.Text = Empty Then OverloadCurrentText.Text = "0" Msg = Msg & vbNewLine & "Overload Current: " & OverloadCurrentText.Text & " A" Msg = Msg & vbNewLine If CaSCText.Text = Empty Then CaSCText.Text = "0" Msg = Msg & vbNewLine & "CaSC: " & CaSCText.Text If CaOLText.Text = Empty Then CaOLText.Text = "0" Msg = Msg & vbNewLine & "CaOL: " & CaOLText.Text If CgText.Text = Empty Then CgText.Text = "0" Msg = Msg & vbNewLine & "Cg: " & CgText.Text 'CiText.Text preset to 0.5 Msg = Msg & vbNewLine & "Ci: " & CiText.Text If MCB Then Ct = 1 If SemiEnclosedFuse Then Ct = 0.725 Msg = Msg & vbNewLine & "Ct: " & Ct 'Reference Data Calculation ' Dim Row As Integer Dim Column As Integer Dim Multiplier As Integer Dim i As Integer Dim CurrentCarryingCapacity As Variant Dim VoltageDrop As Integer If TwoCoresCables Then Column = 2 If ThreeFourCoresCables Then Column = 38 If DC Then Column = Column + 0 If DC Then Multiplier = 1 If SingleAC Then Column = Column + 8 If SingleAC Then Multiplier = 4 If ThreeAC Then Column = Column + 0 If ThreeAC Then Multiplier = 4 If Method1 Then Column = Column + Multiplier * 0 If Method3 Then Column = Column + Multiplier * 1 If Method4 Then Column = Column + Multiplier * 2 If Method11 Then Column = Column + Multiplier * 3 If Method12Horizontal Then Column = Column + Multiplier * 4 If Method12Vertical Then Column = Column + Multiplier * 5 If Method13 Then Column = Column + Multiplier * 6 If OneTrefoil Then Column = Column + Multiplier * 7 If ElevenTrefoil Then Column = Column + Multiplier * 8 If TwelveTrefoil Then Column = Column + Multiplier * 9 If DC Then VoltageDrop = 9 If DC Then ReturnColumn = VoltageDrop - Column + 1 If SingleAC Then VoltageDrop = Column + 3 If ThreeAC Then VoltageDrop = Column + 3 Msg = Msg & vbNewLine & VoltageDrop If Aluminium Then CurrentCarryingCapacity = WorksheetFunction.VLookup(LoadCurrentText.Text, Worksheets("WorksheetName").Range(Cells(10, Column), Cells(26, VoltageDrop)), ReturnColumn, False) End If If Copper Then CurrentCarryingCapacity = WorksheetFunction.VLookup(LoadCurrentText.Text, Worksheets("WorksheetName").Range(Cells(28, Column), Cells(49, VoltageDrop)), ReturnColumn) End If Msg = Msg & vbNewLine & Column Msg = Msg & vbNewLine & i Msg = Msg & vbNewLine & VoltageDrop Msg = Msg & vbNewLine & WorksheetName Msg = Msg & vbNewLine & CurrentCarryingCapacity Display9.Text = Msg Display9.MultiLine = True End Sub Private Sub CancelButton_Click() Unload CableSizingSelection End Sub
