Results 1 to 6 of 6
Thread: Sum Between Values Within The Same Range
    Hi Guys,
    I have an excel list of Magazine quantities in Cell C. The list includes numbers from 1 to 1000. This list has repeating values too, that is 1 is present multiple times in the same list and so on.
    I need a formula to sum the following:
    Sum of all magazines with the quantity value of 1's
    Sum of all magazines with the quantity value between 2's & 9's (2's & 9's should be included too)
    Sum of all magazines with the quantity value between 10's & 24's (10's & 24's should be included too)
    Sum of all magazines with the quantity value between 25's & 49's (25's & 49's should be included too)
    Sum of all magazines with the quantity value between 50's & 99's (50's & 99's should be included too)
    Sum of all magazines with the quantity value greater than 100's (100 also to be included)
    Thanks,
    Siyab
    Apr 2012
    You have used the term Sum. Does this mean you want to sum the values in Column c for each of the characteristics or you want a count of Column c for each of the characteristics. This is unclear in your request.
    I want the sum of the values in each category.
    Apr 2012
    See attached worksheet example
    Member p45cal's Avatar
    Oct 2013
    Quote Originally Posted by alansidman View Post
    A slight tweak to C6's formula from
    =SUMIFS($C$2:$C$1001,$C$2:$C$1001,">51",$C$2:$C$1001,"<100")
    to
    =SUMIFS($C$2:$C$1001,$C$2:$C$1001,">49",$C$2:$C$1001,"<100")
    Apr 2012
    @p45cal
    Thanks for finding and fixing that.
  1. Replies: 3
    Last Post: 08-10-2013, 09:42 PM
  2. Replies: 8
    Last Post: 04-29-2013, 08:36 PM
  3. Replies: 11
    Last Post: 04-07-2013, 07:51 PM
  4. Sum values based on multiple criteria
    By Jorrg1 in forum Excel Help
    Last Post: 01-07-2013, 03:04 PM
  5. Sum values based on multiple criteria
    By vmath in forum Excel Help
    Last Post: 05-07-2012, 08:53 AM
