try this one. adjust the ranges accordingly.
Code:Option Explicit Sub Sort1() Dim NonBlankData(), n As Long, r As Long, c As Long Dim WholeData WholeData = Range("R3:AC17").Value2 ReDim NonBlankData(1 To UBound(WholeData, 1), 1 To UBound(WholeData, 2)) For r = 1 To UBound(WholeData, 1) '//check whether the first column has data. if so, proceed. Replace the 1 with appropriate column to check If Len(WholeData(r, 1)) Then n = n + 1 For c = 1 To UBound(WholeData, 2) NonBlankData(n, c) = WholeData(r, c) Next End If Next If n Then With Range("AE3") .Resize(n, UBound(NonBlankData, 2)).Value2 = NonBlankData With .Resize(n, UBound(NonBlankData, 2)) .sort Key1:=.Cells(1, 1), Order1:=xlAscending, Key2:=.Cells(1, 8), _ Order2:=xlDescending, Key3:=.Cells(1, 9), Order3:=xlAscending, _ Header:=xlGuess, OrderCustom:=1, MatchCase:=False, Orientation:= _ xlTopToBottom, DataOption1:=xlSortNormal, DataOption2:=xlSortNormal, _ DataOption3:=xlSortNormal End With End With End If End Sub
