The following code adds Labels to Userform1. However all the Labels appear on top of each other at the top left of the userform. What might the problem be?
Thanks for your helpCode:Sub AddControls() Dim UFvbc As VBComponent Dim c, lb As Control Dim r As Long Dim x As VBIDE.VBProject ' Make sure access to the VBProject is allowed On Error Resume Next Set x = Workbooks(1).VBProject If Err <> 0 Then MsgBox "Your security settings do not allow this macro to run.", vbCritical Exit Sub End If Set UFvbc = x.VBComponents("Userform1") ' Delete all controls, if any For Each c In UFvbc.Designer.Controls UFvbc.Designer.Controls.Remove c.Name Next c ' Add Labels For r = 1 To 10 Set lb = UFvbc.Designer.Controls.Add("Forms.label.1") With lb .Width = 25 .Height = 25 .Left = 10 .Top = (r * .Height) + 35 .Caption = Worksheets(3).Cells(r, 1) .Tag = "ItemNo " & r .Name = "lbItemNo" & r End With 'Initialise the userform VBA.UserForms.Add ("Userform1") End Sub
