Results 1 to 7 of 7
Thread: Insert salutation
    Aug 2011
    Insert salutation
    Hi Friends,
    I have attached macro which will help me to send work sheet thru outlook mail.
    In this macro i am using "HI" in front of Persons Name.
    can we use Good morning,Good afternoon or good Evening word based on timing instead of "Hi"
    if we can kindly help with the VBA coding.
    Many thanks in advance
    Regards,
    Prabhu
    Apr 2012
    Here is some code that you can use to test time of day. Insert as I have here:
    Dim StrBody As String
            Dim LTime As String
            If Time > 0 And Time < #11:59:59 AM# Then
            LTime = "Good Morning"
            ElseIf Time > #12:00:00 PM# And Time < #6:00:00 PM# Then
            LTime = "Good Afternoon"
            ElseIf Time > #6:00:00 PM# And Time < #11:59:59 PM# Then
            LTime = "Good Evening"
            StrBody = LTime & " Mr.abcd... ," & vbCrLf & _
                    vbCrLf & _
                    "Pls find the Attached  Outstanding Report as on" & " " & FormatDateTime(Date, vbLongDate) & "." & vbCrLf & _
                    vbCrLf & _
    Aug 2011
    Thank you so much!
    It is working good.
    i have a one more small correction.
    Even after inserting the code "vbCrLf" all are printing in the first line i.e. Name and the message (Pls find the Attached ...)
    can we move the message to next line? if so kindly help.
    Regards,
    Prabhu
    Apr 2012
    You may want to use chr(13) instead.
    Read this link and try the different variations:
    Force carriage return in string - Access World Forums
    Aug 2011
    Hi Alansidman,
    I am sorry, i tried but could not bring the text to the new line.
    Moderator
    Jul 2012
    Try
    .htmlbody = "<HTML><BODY><p> " & LTime & " Mr.abcd... ," & " <br /> </p>" & _
                 "<p>Pls find the Attached  Outstanding Report as on " & FormatDateTime(Date, vbLongDate) & "." & "  <br /> <br /> </p>" & _
                 "<p> ========================================================================================  </p>"
    Aug 2011
    Thank you so much!!
  1. Choose A Salutation Based On Time Using VBA
    By Prabhu in forum Excel Help
    Last Post: 10-26-2013, 11:18 AM
  2. Insert Value When A Conditin is Met
    By Ajit in forum Excel Help
    Last Post: 09-12-2013, 06:58 PM
  3. Automatically Insert Row
    Last Post: 12-21-2012, 06:43 PM
  4. Insert Picture in a Cell UDF
    Last Post: 12-07-2012, 04:49 PM
  5. help with after insert event in Access 10
    By richlyn in forum Access Help
    Last Post: 03-03-2012, 10:49 PM
