Can some show me how to rewrite code 2 using the instructions and example from the first code. I'm trying to get code 2 to do a on going calculation.
The first code is a the step by step instructions on using the VBA event macro.
for doing a ongoing calculation In Excel 2007
Open the file where this is to be used
Select the sheet where this is to be used
Right click the sheet tab
Select: View Code (this will open the VB editor)
Copy the code below and paste it into the window that opens on the right hand side of the screen:
[Select Code] copy to clipboard
Code:Private Sub Worksheet_Change(ByVal Target As Excel.Range) With Target If .Address(False, False) = "BY6" Then If IsNumeric(.Value) Then Application.EnableEvents = False Range("GU").Value = Range("GU3").Value + .Value Application.EnableEvents = True End If End If End With End Sub
The code above shows how to make BY6 add to GU3 daily when I copy and paste special (value) and
it works. but when I ex-span the ranges is where I mess up.
I'm Wanting to make changes to the code below so it will do on going 30 day calculations. can this be done?
I know my codes below do not work because when I copy and paste special (value) to BY6:DP20
The target ranges GU3 THRU JJ71 only show the values from BY6:DP20 and do not add to the totals
already in GU3 thru JJ71.
How can I change the code below (change something, delete something, add something) to get it to do a on going calculation.
I was told to make what I wanted to work,I would have to write the code using Adding an accumulator for multiple cells.Code:Private Sub Worksheet_Change(ByVal Target As Excel.Range) '//if the target range is in anywhere on range "BY6:DP20" If Not Intersect(Target, Range("BY6:DP20")) Is Nothing Then With Target If IsNumeric(.Value) Then Application.EnableEvents = False Range("GU3").Value = Range("HB218").Value + 1 Range("HG3").Value = Range("HN218").Value + 1 Range("HS3").Value = Range("HZ218").Value + 1 Range("IE3").Value = Range("IL181").Value + 1 Range("IQ3").Value = Range("IX181").Value + 1 Range("JC3").Value = Range("JJ71").Value + 1 Application.EnableEvents = True End If End With End If End Sub
does anyone know how that is done?
