Hi Ramakrishnan,
Try this. Thanks to Ron Debruin
In a standard module
Again in a standard module. (Better in a new module)Code:Public rsCon As Object Public rsData As Object Dim arrFields() As String Dim blnFieldStored As Boolean Public Sub GetData(SourceFile As Variant, SourceSheet As String, SourceRange As String, _ Header As Boolean, UseHeaderRow As Boolean, Fname As String) 'Original code: Ron Debruin ' 30-Dec-2007, working in Excel 2000-2007 Dim szConnect As String Dim szSQL As String Dim lCount As Long Dim wbkActive As Workbook Dim wbkNew As Workbook Set wbkActive = ThisWorkbook ' Create the connection string. If Header = False Then If Val(Application.Version) < 12 Then szConnect = "Provider=Microsoft.Jet.OLEDB.4.0;" & _ "Data Source=" & SourceFile & ";" & _ "Extended Properties=""Excel 8.0;HDR=No"";" Else szConnect = "Provider=Microsoft.ACE.OLEDB.12.0;" & _ "Data Source=" & SourceFile & ";" & _ "Extended Properties=""Excel 12.0;HDR=No"";" End If Else If Val(Application.Version) < 12 Then szConnect = "Provider=Microsoft.Jet.OLEDB.4.0;" & _ "Data Source=" & SourceFile & ";" & _ "Extended Properties=""Excel 8.0;HDR=Yes"";" Else szConnect = "Provider=Microsoft.ACE.OLEDB.12.0;" & _ "Data Source=" & SourceFile & ";" & _ "Extended Properties=""Excel 12.0;HDR=Yes"";" End If End If If SourceSheet = "" Then ' workbook level name szSQL = "SELECT * FROM " & SourceRange$ & ";" Else ' worksheet level name or range szSQL = "SELECT * FROM [" & SourceSheet$ & "$" & SourceRange$ & "];" End If On Error GoTo SomethingWrong If rsCon Is Nothing Then Set rsCon = CreateObject("ADODB.Connection") Set rsData = CreateObject("ADODB.Recordset") End If If Not rsCon.State = 1 Then rsCon.Open szConnect If rsData.State = 1 Then rsData.Close rsData.Open szSQL, rsCon, 0, 1, 1 ' Check to make sure we received data and copy the data If Not rsData.EOF Then Set wbkNew = Workbooks.Add If Not blnFieldStored Then For i = 1 To rsData.Fields.Count ReDim Preserve arrFields(1 To i) arrFields(i) = rsData.Fields(i - 1).Name Next blnFieldStored = True End If 'Add the header cell in each column if the last argument is True With wbkNew.Worksheets(1) .Cells(1, 1).Resize(, UBound(arrFields)) = arrFields .Cells(2, 1).CopyFromRecordset rsData End With wbkNew.SaveAs ThisWorkbook.Path & "\" & Fname, 51 wbkNew.Close Set wbkNew = Nothing Else MsgBox "No records returned from : " & SourceFile, vbCritical End If ' Clean up Set wbkActive = Nothing Exit Sub SomethingWrong: MsgBox "The file name, Sheet name or Range is invalid of : " & SourceFile, _ vbExclamation, "Error" On Error GoTo 0 End Sub
Adjust the rows and file path.Code:Sub kTest() Dim i As Long Dim Fname As String Dim n As Long Const NewWbkRows As Long = 40000 '<<==== adjust this rows Const TotalRows As Long = 300000 '<<==== adjust this rows Const SourceFile As String = "D:\Temp\Sample.xlsx" '<<==== adjust to suit For i = 1 To TotalRows Step NewWbkRows n = n + 1 If i = 1 Then GetData SourceFile, "Sheet1", _ "A" & i & ":H" & i + NewWbkRows - 1, True, True, "NewFile" & n Else GetData SourceFile, "Sheet1", _ "A" & i & ":H" & i + NewWbkRows - 1, True, False, "NewFile" & n End If Next If rsData.State = 1 Then rsData.Close Set rsData = Nothing If rsCon.State = 1 Then rsCon.Close Set rsCon = Nothing End Sub
