Thread: VBA Macro To Print With Custom From And To Page Numbers
    Sep 2013
    hi expert..
    i hope you can give solution about my code macro, below :
    Sub PrintForms()
        Dim StartRow As Integer
        Dim EndRow As Integer
        Dim Msg As String
        Dim i As Integer
        Sheets("Resume").Activate
        StartRow = Range("StartRow")
        EndRow = Range("EndRow")
        If StartRow > EndRow Then
            Msg = "ERROR" & vbCrLf & "The starting row must be less than the ending row!"
            MsgBox Msg, vbCritical, APPNAME
        For i = StartRow To EndRow
            Range("RowIndex") = i
            If Range("Preview") Then
                ActiveSheet.PrintPreview
                ActiveSheet.PrintOut
        Next i
    my question, how can modify/adding/insert new code, that macro have can be printing multiple pages e.g. print 1-4 pages or 6-12 pages, etc...
    my problem with code that above, only running print one by one.....
    i'am newbie about macro...
    thanks...superman.....
    https://www.youtube.com/watch?v=bRd4mJglWiM&lc=UgxRmh2gFhpmHNnPemR4AaABAg. A0opm95t2XEA0q3KshmuuY
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314619#p314619
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314600#p314600
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314599#p314599
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314274#p314274
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314229#p314229
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40621&p=314195#p314195
    https://www.eileenslounge.com/viewtopic.php?f=36&t=39706&p=314110#p314110
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314081#p314081
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314078#p314078
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=314062#p314062
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40597&p=314054#p314054
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313971#p313971
    https://www.eileenslounge.com/viewtopic.php?f=30&t=40533&p=313909#p313909
    https://www.eileenslounge.com/viewtopic.php?f=27&t=40574&p=313879#p313879
    The first two arguments for PrintOut are [From] and [To]
    So your code could use
    Sub PrintForms()
        Dim Msg As String
        Dim i As Integer
        Dim lngFrom As Long
        Dim lngTo As Long
        lngFrom = 6
        lngTo = 12
                ActiveSheet.PrintOut lngFrom, lngTo
                'But to make it more idiot proof, you could use the following
                'ActiveSheet.PrintOut Application.Min(Sheets.Count, lngFrom), Application.Min(Sheets.Count, lngTo)
        Next i
  1. Macro To Print Selected Range
    By ciapul12 in forum Excel Help
    Last Post: 11-15-2013, 11:23 PM
  2. Replies: 14
    Last Post: 05-25-2013, 06:55 AM
  3. Macro To Delete Numbers With Trailing Character
    Last Post: 04-05-2013, 08:14 PM
  4. Print VBA cancel command not working
    By Tony in forum Excel Help
    Last Post: 02-07-2013, 07:09 PM
  5. Replies: 0
    Last Post: 03-06-2012, 03:55 AM
