Results 1 to 10 of 17
Thread: Looking at data sheet and then transferring data according to date to fixed range
    Jul 2013
    I am using a Userform to find data in a sheet called Team A.With the selected date and ranges in userform it then searches sheet Team A.It then transfer that information to a sheet called Group A.
    The date will be in Column B.It will look at Planned stops ( range K8:M1000) that match that date and transfer to sheet Group A range O6:Q11, same for Unplanned stops - internal & Unplanned Stops - external..(internal & external stops leaves out the transfer of Part and Fault)
    I will do the same for sheets Group B and Group C
    Put this code in the Userform module.
        Dim wksSource   As Worksheet
        Dim wksDest     As Worksheet
        Dim n           As Long
        Dim i           As Long
        Dim j           As Long
        Dim lngDate     As Long
        Dim rngDest     As Range
        Dim Data, arrOP()
        If Me.ComboBox1.ListIndex = -1 Then Exit Sub
        j = Me.ListBox1.ListIndex
        If j = -1 Then Exit Sub
        lngDate = CLng(DateValue(Me.ComboBox1.Value))
        Set wksSource = ThisWorkbook.Worksheets("team a")
        Set wksDest = ThisWorkbook.Worksheets("group a")
        Data = wksSource.Range("b8:v" & wksSource.Range("b" & wksSource.Rows.Count).End(xlUp).Row).Value2
        If IsArray(Data) Then
            ReDim arrOP(1 To UBound(Data, 1), 1 To 3)
            For i = 1 To UBound(Data, 1)
                If Data(i, 1) = lngDate Then
                    n = n + 1
                    Select Case j 'Listbox Selection
                        Case 0 'Planned stop
                            arrOP(n, 1) = CDate(Data(i, 1)) 'date
                            arrOP(n, 2) = Data(i, 10) 'Reason
                            arrOP(n, 3) = Data(i, 11) 'time
                        Case 1
                            arrOP(n, 2) = Data(i, 13) 'part
                            arrOP(n, 3) = Data(i, 16) 'time
                        Case 2
                            arrOP(n, 2) = Data(i, 18) 'Reason
                            arrOP(n, 3) = Data(i, 20) 'time
            If n Then
                Set rngDest = wksDest.Range("o5").Offset(j * 9 + 1)
                rngDest.Resize(6, 3).ClearContents
                rngDest.Resize(n, 3) = arrOP
        Unload Me
    Jul 2013
    Hi Admin
    I placed in the userform the code
    I placed some dummy figures in the sheet but it did not transfer
    Have I missed something
    That's because the date is not matching with the data.
    Jul 2013
    My apologies
    It does though place more then 1 date in each grouping.It also does not find the last entry as it places down the rows...it is impressive though
    Try this.
        Dim n           As Long
        Dim i           As Long
        Dim j           As Long
        Dim lngDate     As Long
        Dim Data, arrOP()
                            'check for data
                            If Len(Data(i, 10)) Then
                                n = n + 1
                        Case 1
                            'check for data
                            If Len(Data(i, 13)) Then
                                n = n + 1
                        Case 2
                            'check for data
                            If Len(Data(i, 18)) Then
                                n = n + 1
            If n Then
        Unload Me
    Jul 2013
    Thanks Admin
    I learnt a bit and changed the code so that i included the comments as well.It works so i guess i got it correct.Also added a delete code.
    My only request is how do i have all 3 items in the listbox transfer at the same time.Press the transfer button once and the 3 listed are transfer simultaneously
    Thank you for your help
    Remove all the codes from the userform module and put this code.
    Dim Data
    Dim arrOP_PS(1 To 6, 1 To 4), PSCounter     As Long
    Dim arrOP_MSI(1 To 6, 1 To 4), MSICounter   As Long
    Dim arrOP_MSE(1 To 6, 1 To 4), MSECounter   As Long
        Dim i           As Long
        Dim j           As Long
        Dim p           As Long
        Dim lngDate     As Long
        Dim LB()        As Long
        If Me.ListBox1.ListIndex = -1 Then Exit Sub
        With Me.ListBox1
            ReDim LB(1 To .ListCount)
            For j = 0 To .ListCount - 1
                If .Selected(j) Then
                    p = p + 1
                    LB(p) = j
        If p Then
            n = 0
                        CREATE_OUTPUT i, LB
                If PSCounter Then
                    wksDest.Range("O6").Resize(UBound(arrOP_PS, 1), UBound(arrOP_PS, 2)).ClearContents
                    wksDest.Range("O6").Resize(PSCounter, UBound(arrOP_PS, 2)) = arrOP_PS
                If MSICounter Then
                    wksDest.Range("O15").Resize(UBound(arrOP_MSI, 1), UBound(arrOP_MSI, 2)).ClearContents
                    wksDest.Range("O15").Resize(MSICounter, UBound(arrOP_MSI, 2)) = arrOP_MSI
                If MSECounter Then
                    wksDest.Range("O24").Resize(UBound(arrOP_MSE, 1), UBound(arrOP_MSE, 2)).ClearContents
                    wksDest.Range("O24").Resize(MSECounter, UBound(arrOP_MSE, 2)) = arrOP_MSE
        Unload Me
        ComboBox1.List = [transpose(text(today()-6+row(1:6),"dd-mmm-yyyy"))]
        vList = ("PLANNED STOPS,UNPLANNED STOPS-INTERNAL,UNPLANNED STOPS-EXTERNAL")
        ListBox1.List = Split(Mid(vList, 1), ",")
    Private Sub CREATE_OUTPUT(ByVal CurrentRow As Long, ByRef LB_Selection() As Long)
        Dim i As Long
        Dim Flg0    As Boolean
        Dim Flg1    As Boolean
        Dim Flg2    As Boolean
        For i = LBound(LB_Selection) To UBound(LB_Selection)
            Select Case LB_Selection(i)
                    'check for data
                    If Len(Data(CurrentRow, 10)) Then
                        If Not Flg0 Then
                            PSCounter = PSCounter + 1
                            arrOP_PS(PSCounter, 1) = CDate(Data(CurrentRow, 1)) 'date
                            arrOP_PS(PSCounter, 2) = Data(CurrentRow, 10) 'Reason
                            arrOP_PS(PSCounter, 3) = Data(CurrentRow, 11) 'time
                            arrOP_PS(PSCounter, 4) = Data(CurrentRow, 12) 'comment
                            Flg0 = True
                Case 1
                    'check for data
                    If Len(Data(CurrentRow, 13)) Then
                        If Not Flg1 Then
                            MSICounter = MSICounter + 1
                            arrOP_MSI(MSICounter, 1) = CDate(Data(CurrentRow, 1)) 'date
                            arrOP_MSI(MSICounter, 2) = Data(CurrentRow, 13) 'part
                            arrOP_MSI(MSICounter, 3) = Data(CurrentRow, 16) 'time
                            arrOP_MSI(MSICounter, 4) = Data(CurrentRow, 17) 'comment
                            Flg1 = True
                Case 2
                    'check for data
                    If Len(Data(CurrentRow, 18)) Then
                        If Not Flg2 Then
                            MSECounter = MSECounter + 1
                            arrOP_MSE(MSECounter, 1) = CDate(Data(CurrentRow, 1)) 'date
                            arrOP_MSE(MSECounter, 2) = Data(CurrentRow, 18) 'Reason
                            arrOP_MSE(MSECounter, 3) = Data(CurrentRow, 20) 'time
                            arrOP_MSE(MSECounter, 4) = Data(CurrentRow, 21) 'comment
                            Flg2 = True
    Jul 2013
    Hi Admin
    Excellent and thanks
    Wish I could code like that
    Jul 2013
    Hi Admin
    I updated the code by adding a extra column to the code.It works but i cannot workout how to clear the extra column.Where do i change please?
    Also i plan on adding another 2 sheets called Team B and Team C.......should i just use the code for Team A and alter to suit Team B and Team C or how would the code be altered to include Team B and Team C with the code already for Team A
    Thank you
  1. Replies: 2
    Last Post: 09-30-2013, 03:40 PM
  2. Replies: 10
    Last Post: 08-31-2013, 06:56 PM
  3. Replies: 3
    Last Post: 07-29-2013, 11:32 PM
  4. Replies: 2
    Last Post: 07-02-2013, 06:52 PM
  5. Replies: 5
    Last Post: 06-15-2013, 12:40 PM
