Results 1 to 10 of 12
Thread: Showing Month Abbreviation With Using 2 Characters
    Jul 2013
    I work in a factory where we use 2 letter month expiry abbreviations. I'm trying to get Excel to show it the same way, but it's limited to Jan, 01, January, etc.
    Is there a way I can get it to show JA instead?
    We have a spreadsheet that autopopulates a 6 month and 9 month expiration from the current date.
    IE 01/12/2013 turns into =M1800+180 (2014/May/30) and =M1800+270 (2014/Aug/28)
    So I can't just write a choose/if formula. I'm not sure there's any way of doing this, any help would be appreciated.
    (I've attached a copy of an example as well)
    May 2013
    Welcome to the forum!
    You can use strings. In B1:
    =YEAR(A1+180)&"/"&UPPER(LEFT(TEXT(A1+180,"mmm"),2))&"/"&DAY(A1+180)
    Jul 2013
    Thanks! This is great, other than it's showing MA for both March and May, JU for June and July etc. I guess that's an issue since we're just cutting off anything past the 2nd letter. These are the abbreviations we use:
    January: JA
    February: FE
    March: MR
    April: AL
    May: MA
    June: JN
    July: JL
    August: AU
    September: SE
    October: OC
    November: NO
    December: DE
    I'm sure this makes everything way more complicated.
    May 2013
    Right, which is why 3 characters are used for abbreviations for month names. If you don't mind using a UDF, what you want can be done and simplified.
    make your own customlist:
    Sub M_snb()
      Application.AddCustomList Split("MA|FE|MR|AL|MA|JN|JL|AU|SE|OC|NO|DE","|")
    May 2013
    For the UDF method, add this to a Module and use it as the comment demonstrates.
    ' =Month2(A1+180)
    Function Month2(aDate As Date) As String
      Dim d() As String
      Application.Volatile False
      d() = Split("JA FE MR AL MA JN JL AU SE OC NO DE")
      Month2 = Year(aDate) & "/" & d(Month(aDate) - 1) & "/" & Day(aDate)
    Dec 2012
    HI
    Maybe try incorporating the LOOKUP function.
    =LOOKUP(MONTH(A1+180),{1,2,3,4,5,6,7,8,9,10,11,12} ,{"JA","FE","MR","AL","MA","JN","JL","AU","SE","OC ","NO","DE"})
    Alternatively the VLOOKUP can be used as well.
    You can format your cells as General and then put this formula in B1 and copy it down...
    =REPLACE(UPPER(TEXT(A1+180,"yyyy/mmm/d")),6,3,CHOOSE(MONTH(A1+180),"JA","FE","MR","AL","MA","JN","JL","AU","SE","OC ","NO","DE"))
    Change the two 180's to 270's in the above formula and use it in cell C1.
    =TEXT(A1+180,"yyyy/") & MID("JAFEMRALMAJNJLAUSEOCNODE",2*MONTH(A1+180)-1,2) & "/" &TEXT(A1+180,"dd")
    Yes, using MID that way is a good idea. You can save a coupe of characters (and a concatenation) by moving the last slash into the last TEXT function call like this...
    =TEXT(A1+180,"yyyy/") & MID("JAFEMRALMAJNJLAUSEOCNODE",2*MONTH(A1+180)-1,2) & TEXT(A1+180,"\/dd")
  1. Custom Charts in Excel :: Comparison RAG Chart Showing Tolerance Limits
    Last Post: 06-13-2013, 09:40 PM
  2. Find Mismatch Characters:
  3. Extract Certain Characters From A Text String
    By bobkap in forum Excel Help
    Last Post: 05-24-2013, 06:25 AM
  4. Excel Chart Showing Values on Angle: Nightingale Chart
    Last Post: 10-17-2012, 06:39 PM
  5. Remove Special Characters :
    Last Post: 03-06-2012, 09:41 PM
