Thread: can be used a single cell for a range of consecutive values?!
    Nov 2013
    Hello everybody,
    I need to work with a big range of numbers... How can I input in a single cell a range of condecutive numbers, like from 1,50 to 10, with intervals of 0,01??? Then I would like to use this single cell in a complex formula, and extract the maximum value.
    What I am trying to do is to not have to write a long serie of cells, each one with values like 1,50; 1,51; 1,52... up to 10,00... So I need some way to put all this in a single cell.
    Thank you in advise!
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgxesLhWNr_zNP0GUdh4AaABAg. 9hI1CQJMLLo9hWn2pGBeSS
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgzkRujoMw9PblmXDQ14AaABAg. 9hJRnEjxQrd9hJoCjomNI2
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgzPZbG7OvUkh35nXDd4AaABAg. 9hJOZEEZa6p9hJqLC7El-w
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgwUcEpm8u6ZW3uOHXx4AaABAg. 9hIlxxGY7t49hJsB2PWxC4
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgyvDj6NWT1Gxyy2JyR4AaABAg. 9hIKlNPeqDn9hJskm92np6
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=Ugwy7qx_kG9iUmMVO_F4AaABAg. 9hI2IGUdmTW9hJuyaQawqx
    https://www.youtube.com/watch?v=pkhazgI3LAo&lc=UgxesLhWNr_zNP0GUdh4AaABAg. 9hI1CQJMLLo9hJwTB9Jlob
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgyG714V_k7odQMrTz14AaABAg. 9h740K6COOA9iHOYYpaAbC
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgxuL6YCUckeUIh9hoh4AaABAg
    https://www.youtube.com/watch?v=2oT4qrHmDMY&lc=UgwGTEyefOX7msIh1wZ4AaABAg. 9h4sd6Vs4qE9h7G-bVm8_-
    You could enter these values one below the other in a single cell by pressing ALT+ENTER for each new line. You must remember that there is a limit to the number of characters that a cell can contain. For Excel 2003, it is 32,767. Not sure what's for the latter versions.
    Quote Originally Posted by Pinos View Post
    Hello everybody,
    There may be a purely mathematical solution to obtain your maximum value, but in order to know if that is the case, we need to see your complex formula.
    Jan 2012
    An ugly way of getting there.
    Cell A1 has the starting number
    Cell A2 has the end number
    Cell A3 has the increment
    Column B needs to be empty (free to use)
    Result in cell E2
    Sub FillNumsBetween()
        Dim rRange As Range
        Dim rFill As Range
        Dim dStop As Double
        Dim rCell As Range
        Dim lr As Long
        Dim temparr
        dStop = Cells(2, 1)   '<----- End Value
        Set rFill = Cells(1, Columns.Count).End(xlToLeft)(1, 2)    '<---- Where it starts filling results
        Cells(1, 1).Copy rFill
        Range(rFill, Cells(Rows.Count, rFill.Column)).DataSeries _
                Rowcol:=xlColumns, Type:=xlLinear, _
                Step:=Range("A3").Value, Stop:=dStop
        lr = Cells(Rows.Count, 2).End(xlUp).Row
        temparr = Range("B1:B" & lr)
        Cells(2, 5) = Join(WorksheetFunction.Transpose(temparr), "; ")
    I hope someone cleans this code up. For now it should help you.
  1. How Get Value From A Cell Range Using VBA
    By ajgcook1983 in forum Excel Help
    Last Post: 09-17-2013, 09:28 AM
  2. Replies: 1
    Last Post: 08-23-2013, 05:19 AM
  3. counting consecutive values in an array
    By 5ko in forum Excel Help
    Last Post: 12-04-2012, 03:49 AM
  4. Count consecutive value in a range using formula
    Last Post: 11-12-2012, 05:23 PM
  5. Concatenate Multiple Lookup Values in Single Cell
    Last Post: 04-06-2012, 09:07 PM
