Quote Originally Posted by Fikile Kentane View Post
Hi Rick
Thanks so much for the "PtInPoly" function. Awesome.
I'm doing field data collection in a meter audit project. My field workers complete a Meter Audit FORM and attach lat/long GIS coordinates for the location of the meters. I cover many areas and most of the time I have to name the areas using my own names. This function helps me locate if the lat/long are inside designated areas.
How I use the "PtInPoly" function is the following: I call it is inside my function in an excel spreadsheet and pass it "X-coord:lat", "Y-coord:long"d a "2-dimensional array of polygon points". My polygon is a closed polygon.
There are about 5000 waypoints points my field database. So, for each waypoint I call the "PtInPoly" and test on which area the waypoint is located. I do this by running a loop for all areas and come out of the loop after finding the matching area.
Wanted to ask if I'm allowed to modify you function and pass it four variables instead of three. Fourth one will be used for looping through all the areas?
When I'm done. I will post the modified function here for you and everyone to see.
Best
Fikile
Note... I removed your quote of my entire original post from your post... no need to burden this forum's servers with duplicate data that does not serve to any real reference purpose in your message.
I am glad that you found my code useful to you. As to your question... sure, feel free to modify it in anyway that is useful to you. None of the code I have posted in this sub-forum is copyrighted, so you can use or modify any of it as needed.
