Thread: Clear ID CARD with commandbutton
    Oct 2013
    I downloaded this workbook which i hope to use with some mods.....with a commandbutton can the ID CARD be cleared of the picture,persons name and colors but leaving the names of the sections in a white cell.....when i select a name again from drowdown list it then again populates the card...the reason for this is i will make 100 ID CARDS
    Cheers
    Rod
    Can you rephrase your question. Not sure I understand it well.
    Sub EF()
    Range("B3:D9").clearContents
    The above should clear all the values in the mentioned range.
    Oct 2013
    If i select the commandbutton it clears the ID CARD...please see attached -what the card would look like after the commandbutton selected to clear data.....if i then select a name from the dropdown list it will then again populate the card with picture and colored cells according to name selected
    I've added a hyphen below in the main list, and also in the Pictures tab. That will give an effect of clearing the card. Have added a code as below to change the name to hyphen
        Me.Range("rngCurrentName").Value = "-"
  1. How To Close A UserForm With A CommandButton
    By jeff in forum Excel Help
    Last Post: 07-21-2013, 12:37 PM
  2. Replies: 9
    Last Post: 12-04-2012, 09:45 PM
  3. Macro To Clear Certain Data Across Many Sheets
    Last Post: 12-04-2012, 09:10 AM
  4. Macro to clear data based on color fill
    Last Post: 12-03-2012, 09:25 AM
  5. VBA Code to Clear the Immediate Window.
    By technicalupload in forum Excel and VBA Tips and Tricks
    Last Post: 09-02-2011, 03:04 PM
