Thread: Calendar dates not populating correctly
jann3891 Calendar dates not populating... 10-24-2013, 12:30 AM
Excel Fox The formula you are using is... 10-24-2013, 08:28 AM
jann3891 Oh man, thank you very much.... 10-24-2013, 07:04 PM
    Oct 2013
    I have a calendar with 2 rows in between every row of dates for notes.
    The first row of dates are correct, but the following 5 rows are all repeat of the first row.
    I need help to modify the formula for the rest of the dates to populate correctly.
    Thank you
    The formula you are using is an array formula. The reason why it was repeating the same dates for each row was because of the transposed numeric array {0;1;2;3;4;5} that was meant for each row.
    So in your case, you should split this formula in to 6 individual rows, each with seperate row index, with the first index starting with 0.
    =IF(MONTH(DATE(YEAR(I1),MONTH(I1),1))<>MONTH(DATE( YEAR(I1),MONTH(I1),1)-(WEEKDAY(DATE(YEAR(I1),MONTH(I1),1))-1)+{0}*7+{1,2,3,4,5,6,7}-1),"",DATE(YEAR(I1),MONTH(I1),1)-(WEEKDAY(DATE(YEAR(I1),MONTH(I1),1))-1)+{0}*7+{1,2,3,4,5,6,7}-1)
    Oct 2013
    you are a genius Excel Fox....
  1. Insert Missing Dates By Comparing Two Lists Of Dates
    Last Post: 10-16-2013, 04:48 PM
  2. List of Dates In DropDown Starting From Today()
    Last Post: 04-10-2013, 05:58 PM
  3. How to Extracting dates and days between 2 dates.
    Last Post: 08-11-2012, 09:11 PM
  5. Visual Plotter basis given dates and activity
    Last Post: 03-07-2012, 02:37 PM
