Results 1 to 10 of 12
Thread: Lock Cells Based On Interior Colour Including Conditional Fomatting
AerosAtar Lock Cells Based On Interior... 10-22-2013, 04:50 PM
Admin Hi Welcome to ExcelFox!! ... 10-22-2013, 09:53 PM
AerosAtar Thanks for the reply (and... 10-22-2013, 11:37 PM
Admin Hi Create a mockup by... 10-23-2013, 10:59 AM
AerosAtar I have attached a... 10-23-2013, 09:12 PM
Admin Hi Can you please try this... 10-23-2013, 11:07 PM
AerosAtar Unfortunately that code does... 10-24-2013, 05:38 PM
Admin Hi OK. Try this. Dim... 10-24-2013, 11:54 PM
AerosAtar Unfortunately this does not... 10-25-2013, 04:40 PM
Admin Essentially which cells you... 10-25-2013, 08:11 PM
AerosAtar Any cell with a light-grey... 10-25-2013, 09:12 PM
Admin Hi IMHO, include all the... 10-25-2013, 11:03 PM
    Oct 2013
    I have the following code in a Worksheet_Change() event that locks cells based on their interior colour.
    Dim cell
    For Each cell In ActiveSheet.Range("A1:Y160")
      If cell.MergeCells = False Then
        Select Case True
          Case cell.Interior.ColorIndex = 15
               cell.Locked = True
          Case Else
               cell.Locked = False
        Set mergedRange = cell.MergeArea
        Select Case True
          Case mergedRange.Interior.ColorIndex = 15
               mergedRange.Locked = True
          Case Else
               mergedRange.Locked = False
    This code works perfectly, locking all cells and mergeareas with a 25% grey background.
    However, some cells/mergeareas contain conditional formatting to change the colour of the background. This conditional formatting is formula-based, as the formatting is based on the contents of other cell(s).
    For example: mergearea(F6:O6)'s formatting is dependent on the value of cell(L4), while cell(Q126)'s formatting is based on the values of cells(Q138, F126 and B126).
    This means that certain cells/mergeareas that should not be locked are being locked (due to having a default 25% grey background), while others that should be locked are not being locked (due to not having a default 25% grey brackgroud).
    I've seen the code on Rick's thread (http://www.excelfox.com/forum/f22/ge...ng-or-not-338/), but I am not sure how to incorporate it into the above (or if there is another way of doing what I want). I am also aware of the DisplayFormat property, but unfortunately this is not an option as I need backward-compatability with Excel 2007 (some users are running 2007, while others are using 2010 - I am coding in 2007).
    I may be able to upload the form that this code is being used in, but am currently seeking confirmation from my employer that I am permitted to do so.
    Try this untested code. You have to define the color depending upon the other cells.
    Dim Cell As Range
    Dim mergedRange As Range
    For Each Cell In ActiveSheet.Range("A1:Y160")
      If Cell.MergeCells = False Then
        Select Case True
          Case Cell.Interior.ColorIndex = 15
               Cell.Locked = True
          Case Else
               Cell.Locked = False
        Set mergedRange = Cell.MergeArea
        Select Case mergedRange.Address(0, 0)
            Case "F6:O6"
                If Range("L4").Value = "Whatever" Then
                    mergedRange.Interior.ColorIndex = 15    'adjust the color index
            Case "Q126"
                'same as above
            Case Else
                Select Case True
                  Case Else
    Oct 2013
    Thanks for the reply (and welcome!).
    If possible, I would prefer to avoid doing single-cell/mergearea specifications in the code. The form is quite complex, with a not-insignificant number of questions, and a significant number of those have impacts on other questions within the form. I already have too many absolute-references in some of the other code, which makes updating in when additional questions are inserted a real chore. (I realise that seeing the form would probably help explain all this, but I am still waiting on an answer from my employer).
    If there is no other way, I will look at switching all of the conditional formatting into the code, but I was really hoping that wouldn't be necessary...
    Create a mockup by putting some dummy values. Be careful that the format of the sheet is same in the mockup version as well.
    Oct 2013
    I have attached a stripped-down version of one page of the form.
    Book1.xlsm
    All of the code for the Command Button Click() events have been stripped out, since they won't work anyway without the rest of the workbook (not to mention being irrelevant to what I am asking about), and I have removed passwords, etc.
    Hopefully this helps show what it is I need/want to accomplish.
    Can you please try this one ?
    Dim Cell    As Range
    Range("A1:Y160").Locked = False
        If Cell.FormatConditions.Count = 0 Then
            If Cell.Interior.ColorIndex = 15 Then Cell.Locked = True
            If Cell.DisplayFormat.Interior.ColorIndex = 15 Then
                If Cell.Borders.ColorIndex = xlNone Then
                    Cell.Locked = True
        If mergedRange.FormatConditions.Count = 0 Then
            If mergedRange.Interior.ColorIndex = 15 Then mergedRange.Locked = True
            'If Cell.Address = "$O$20" Then Stop
            If mergedRange.DisplayFormat.Interior.ColorIndex = 15 Then
                If mergedRange.Borders(xlEdgeTop).ColorIndex = xlNone Then
    Oct 2013
    Unfortunately that code does not work due to the DisplayFormat property, which is not present in Excel 2007 (this line of the code
    As stated in my original post, I need to ensure compatability with 2007 due to not all users having 2010 installed (me being one of them).
    OK. Try this.
    Dim Cell    As Range
    Dim xlVer   As Long
    Dim dColor  As Long
    xlVer = Val(Application.Version)
            If xlVer > 12 Then
                        Cell.Locked = True
                dColor = DisplayedColor(Cell, True)
                If dColor = 15 Then
                    'If Cell.Borders.ColorIndex = xlNone Then
                        Cell.Locked = True
                    'End If
            If xlVer > 12 Then
                dColor = DisplayedColor(mergedRange.Cells(1), True)
                If dColor = 15 Then
    in a standard module, use Rick's Function
    ' Arguments
    ' Cell - Required Range, not a String value, for a **single** cell
    ' CellInterior - Optional Boolean (Default = True)
    '                True makes function return cell's Interior Color or ColorIndex based on
    '                the ReturnColorIndex argument False makes function return Font's Color or
    '                ColorIndex based on the ReturnColorIndex argument
    ' ReturnColorIndex - Optional Boolean (Default = True)
    '                    True makes function return the ColorIndex for the cell property determined
    '                    by the CellInterior argument False make function return the Color for the
    '                    cell property determined by the CellInterior argument
    Function DisplayedColor(Cell As Range, Optional CellInterior As Boolean = True, _
                            Optional ReturnColorIndex As Long = True) As Long
      Dim X As Long, Test As Boolean, CurrentCell As String
      If Cell.Count > 1 Then Err.Raise vbObjectError - 999, , "Only single cell references allowed for 1st argument."
      CurrentCell = ActiveCell.Address
      For X = 1 To Cell.FormatConditions.Count
        With Cell.FormatConditions(X)
          If .Type = xlCellValue Then
            Select Case .Operator
              Case xlBetween:      Test = Cell.Value >= Evaluate(.Formula1) And Cell.Value <= Evaluate(.Formula2)
              Case xlNotBetween:   Test = Cell.Value <= Evaluate(.Formula1) Or Cell.Value >= Evaluate(.Formula2)
              Case xlEqual:        Test = Evaluate(.Formula1) = Cell.Value
              Case xlNotEqual:     Test = Evaluate(.Formula1) <> Cell.Value
              Case xlGreater:      Test = Cell.Value > Evaluate(.Formula1)
              Case xlLess:         Test = Cell.Value < Evaluate(.Formula1)
              Case xlGreaterEqual: Test = Cell.Value >= Evaluate(.Formula1)
              Case xlLessEqual:    Test = Cell.Value <= Evaluate(.Formula1)
          ElseIf .Type = xlExpression Then
            Cell.Select
            Range(CurrentCell).Select
          If Test Then
            If CellInterior Then
              DisplayedColor = IIf(ReturnColorIndex, .Interior.ColorIndex, .Interior.Color)
              DisplayedColor = IIf(ReturnColorIndex, .Font.ColorIndex, .Font.Color)
            If Err.Number <> 0 Then GoTo 1
            Exit Function
        DisplayedColor = IIf(ReturnColorIndex, Cell.Interior.ColorIndex, Cell.Interior.Color)
        DisplayedColor = IIf(ReturnColorIndex, Cell.Font.ColorIndex, Cell.Font.Color)
      Err.Clear
    Oct 2013
    Unfortunately this does not work either - no cells get locked (however, see below).
    If I change .Borders.ColorIndex = xlNone to .Borders.ColorIndex = 16, the the following behaviour is observed:
    • In 2007 the code still does not lock any cells/mergeareas, regardless of their colour.
    • In 2010 it locks some cells/mergeareas, but not others, and also does not unlock some cells/mergeareas after they have been locked the first time - it all seems to be getting applied inconsistently.
    For example, it locks K64:L64, but not K65:L65. It also locks all of the cells/mergeareas in the Combined Fund Heading 'table' (F125:W137), but does not Unlock them when they should be available (set F10 to "Standard Proposal (Research)" and L89 to either "FEC" or "Non-FEC").
    In addition, the code takes an excessive amount of time (>2 minutes) to execute in 2007, causing Excel to become non-responsive (even being reported in task manager as 'Not Responding') during that period.
    Essentially which cells you want to lock/unlock ? Like, you do not want to lock those cells which is having a border or colorindex having 48 etc..
  1. Replies: 4
    Last Post: 07-04-2013, 01:56 PM
  2. Lock Cells After Data Entered
    Last Post: 06-28-2013, 10:52 PM
  3. Nth Working Day Including Saturday
    By Excel Fox in forum Download Center
    Last Post: 10-10-2012, 02:41 AM
  4. Conditional Format Based On Percentage Variance
    By srizki in forum Excel Help
    Last Post: 10-09-2012, 03:28 AM
  5. Lock cells on the basis of date VBA
    Last Post: 09-27-2011, 03:56 PM
