Results 1 to 6 of 6
Thread: How To Shorten Superfluous Code From Recorded Macro
    Jun 2013
    Sub Macro1()
        Range("E4:N23").Select
        Selection.Borders.LineStyle = xlContinuous
    Don't need to write 'Select'
    Range("E4:N23").Borders.LineStyle = xlContinuous
    May 2013
    To go beyond the recorder: Beyond Excel's recorder
    Oct 2013
    Thanks for the help
    I used the recorder and deleted much of the code....i attached workbook....could this be made even simpler?
    Regards
    RK
    May 2013
    The fewer times that you reference an object the better. This is easy to read anyway.
    Private Sub CommandButton2_Click()
      With Range("E4:N4")
        .Interior.ColorIndex = 3
        .Font.Bold = True
        .Font.Size = 16
        .Font.Color = rgbWhite
        .FormulaR1C1 = "=RC[-1]+1"
      Range("E4").FormulaR1C1 = "=TODAY()"
      Columns("E:N").ColumnWidth = 17.14
  1. MACRO CODE TO KNOW MONTH and QUATER
    By Prabhu in forum Excel Help
    Last Post: 09-27-2013, 10:16 PM
  2. Replies: 1
    Last Post: 08-23-2013, 06:33 PM
  3. Shorten VBA Code By Removing Redundant Superfluous Code
    Last Post: 08-15-2013, 09:09 PM
  4. Replies: 0
    Last Post: 07-24-2013, 11:20 PM
