Results 1 to 10 of 12
Thread: USER FORM ISSUES: Clear data from various ranges using checkboxes and other issues.
  1. #3
    Jul 2013
    @snb
    If you see the attached image you will probably understand better what I am trying to do.
    I want to click on one or more months to select the monthly data range and then press the button to actually delete them.
    So I modified your code by replacing ClearContents with Selcet, intending to leave clear contents for the command button.
    The problem is that if I click one month then the data for this month is selected, but when selecting a second month then there is no union of the ranges... instead the range associated to this month is selected and the other selection is lost. Any idea?
    @ bakerman: I think that this did that job as intended, sorry to have missed your reply before posting again...
    Thank you both!
  1. Sending Data From User Form To First Empty Row Of Sheets
    Last Post: 08-14-2013, 11:04 PM
  2. Replies: 9
    Last Post: 12-04-2012, 09:45 PM
  3. Macro To Clear Certain Data Across Many Sheets
    Last Post: 12-04-2012, 09:10 AM
  4. Macro to clear data based on color fill
    Last Post: 12-03-2012, 09:25 AM
  5. Adding A Menu Bar To A User Form
    Last Post: 05-05-2011, 04:05 AM
