Results 1 to 10 of 12
Thread: USER FORM ISSUES: Clear data from various ranges using checkboxes and other issues.
    Jul 2013
    I have an excel file with a sheet named Schedule that contains cell ranges for 12 months ( they are named sep_std, oct_std, noe_std, dec_std,....etc....,aug_std).
    I have also made a userform that has 12 checkboxes one for each month and I want to associate the checkbox with the ranges mentioned,
    for example Checkbox1 for sep_std, Checkbox2 for oct_std, and so on ending with Checkbox12 for aug_std, so as to be able to delete the
    contents of the selected ranges for every month that is clicked.
    Started by using the code below but this would be for one month only
    If CheckBox1.Value = True Then
        Worksheets("Schedule").Activate
        Range("sep_std").Select
        Selection.ClearContents
    Then I thought that I could use Union method and I wrote this code
    If CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True And CheckBox5.Value = True And CheckBox6.Value = True And CheckBox7.Value = True And CheckBox8.Value = True And CheckBox9.Value = True And CheckBox10.Value = True And CheckBox11.Value = True And CheckBox12.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std"), Range("jan_std"), Range("feb_std"), Range("mar_std"), Range("apr_std"), Range("may_std"), Range("jun_std"), Range("jul_std"), Range("aug_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True And CheckBox5.Value = True And CheckBox6.Value = True And CheckBox7.Value = True And CheckBox8.Value = True And CheckBox9.Value = True And CheckBox10.Value = True And CheckBox11.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std"), Range("jan_std"), Range("feb_std"), Range("mar_std"), Range("apr_std"), Range("may_std"), Range("jun_std"), Range("jul_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True And CheckBox5.Value = True And CheckBox6.Value = True And CheckBox7.Value = True And CheckBox8.Value = True And CheckBox9.Value = True And CheckBox10.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std"), Range("jan_std"), Range("feb_std"), Range("mar_std"), Range("apr_std"), Range("may_std"), Range("jun_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True And CheckBox5.Value = True And CheckBox6.Value = True And CheckBox7.Value = True And CheckBox8.Value = True And CheckBox9.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std"), Range("jan_std"), Range("feb_std"), Range("mar_std"), Range("apr_std"), Range("may_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True And CheckBox5.Value = True And CheckBox6.Value = True And CheckBox7.Value = True And CheckBox8.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std"), Range("jan_std"), Range("feb_std"), Range("mar_std"), Range("apr_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True And CheckBox5.Value = True And CheckBox6.Value = True And CheckBox7.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std"), Range("jan_std"), Range("feb_std"), Range("mar_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True And CheckBox5.Value = True And CheckBox6.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std"), Range("jan_std"), Range("feb_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True And CheckBox5.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std"), Range("jan_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True And CheckBox4.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std"), Range("dec_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True And CheckBox3.Value = True Then
        Union(Range("sep_std"), Range("oct_std"), Range("nov_std")).Select
        ElseIf CheckBox1.Value = True And CheckBox2.Value = True Then
        Union(Range("sep_std"), Range("oct_std")).Select
        ElseIf CheckBox1.Value = True Then
    This has worked but it partially did what I wanted. Meaning that if the months were selected sequentially it would have no problem.
    But in case I selected 3 checkboxes i.e. Checkbox1 (September) , Checkbox4(December) and Checkbox12(August) then the code failed
    to clear the contents of these months (apparently).
    Any suggestion of how to overcome this??
    BTW I will have to ask a few more questions about this userform but I will do so later. I need to focus on this now.
    Thanx in advance for any reply.
    Mr.B.
    private Sub CheckBox1_change()
         If CheckBox1.Value  Then   Range("sep_std").ClearContents
    end sub
    private Sub CheckBox2_change()
         If CheckBox2.Value  Then   Range("oct_std").ClearContents
    end sub
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa6BSa173Z
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa6-64Xpgl
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa5ms39yjd
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa5ZXJwRCM
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa4Pr15NUt
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABa4I83JelY
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HABa3tnAjhZU
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HABa3KswxL3c
    https://www.youtube.com/watch?v=suUqEo3QWus&lc=UgyBXFxnVWT3pqtdqPx4AaABAg
    https://www.youtube.com/watch?v=suUqEo3QWus&lc=Ugi53h84LUm5bHgCoAEC.7-H0Z7-COoGABZFQ8vjEvY
    https://www.youtube.com/watch?v=3t8Mk4URi6g&lc=UgzoakhRXOsCaoRm_Nd4AaABAg. 8xzeMdC8IOGABZ8N9O-O8p
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgxREWxgx2z2Lza_0st4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgyikSWvlxbWS24NBeR4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=UgwNiH4hhyrd2UjDK8d4AaABAg
    https://www.youtube.com/watch?v=C43btudYyzA&lc=Ugyf349Ue6_4umFfNUB4AaABAg. 8mjgPNoTt_HAAf952WoUti
    https://www.youtube.com/watch?v=hz4vb48wzMM&lc=Ugy2N3gvXBNrvWpojqR4AaABAg
    Moderator
    Jul 2012
    For i = 1 To 12
        If Me("Checkbox" & i) Then Sheets("Schedule").Range(Choose(i, "sep_std", "oct_std", "nov_std", "dec_std", _
            "jan_std", "feb_std", "mar_std", "apr_std", "may_std", "jun_std", "jul_std", "aug_std")).ClearContents
    Jul 2013
    @snb
    If you see the attached image you will probably understand better what I am trying to do.
    I want to click on one or more months to select the monthly data range and then press the button to actually delete them.
    So I modified your code by replacing ClearContents with Selcet, intending to leave clear contents for the command button.
    The problem is that if I click one month then the data for this month is selected, but when selecting a second month then there is no union of the ranges... instead the range associated to this month is selected and the other selection is lost. Any idea?
    @ bakerman: I think that this did that job as intended, sorry to have missed your reply before posting again...
    Thank you both!
    Jul 2013
    Now I have another stupid question I have extended the code to
            For i = 13 To 24
                If Me("Checkbox" & i) Then Sheets("Schedule").Range(Choose(i, "sep_pay", "oct_pay", "nov_pay", "dec_pay", _
                    "jan_pay", "feb_pay", "mar_pay", "apr_pay", "may_pay", "jun_pay", "jul_pay", "aug_pay")).ClearContents
    so as to clear the respective ranges of the payment status per month to but it gets stuck on
    what went wrong?? I mean it worked great with the monthly ranges that contain the names of students, it should similarly work on payment status monthly ranges. No?
    Moderator
    Jul 2012
    First of all press F1 in VBA and lookup Choose
            For i = 13 To 24
                If Me("Checkbox" & i) Then Sheets("Schedule").Range(Choose(i-12, "sep_pay", "oct_pay", "nov_pay", "dec_pay", _
    Jul 2013
    OK thanks for the info, indeed it works now, but what if I had j instead of i, why would this also crash?
     For j = 13 To 24
                If Me("Checkbox" & j) Then Sheets("Schedule").Range(Choose(j, "sep_pay", "oct_pay", "nov_pay", "dec_pay", _
    Guess I 'd better check F1 first but thanx anyway for your help both times.
    Moderator
    Jul 2012
    Simple.
     For j = 13 To 24
                If Me("Checkbox" & j) Then Sheets("Schedule").Range(Choose(j-12, "sep_pay", "oct_pay", "nov_pay", "dec_pay", _
    Jul 2013
    I had figured it myself about the code. I asked sth different but nevermind it got clear by reading abt Choose.
    Thanks again for the help provided.
    Jul 2013
    This thing has gone further than I thought so I have one last question ...
    I am attaching a sample of the excel file that I am working on so as to be better understood.
    I have a weekly schedule for a guitar teacher that he has max 5 classes per day.
    I want for every student to have a count of the times that the payment status is false or cancel
    I have used named ranges for the cells that correspond to names and payment status and
    tried with instr to search first for each student name and then offset 2 rows to check for
    false or cancelled in the payment status but it was a fiasco so I am ahamed to share the code.
    I appreciate any ideas.
    thanks a priori
  1. Sending Data From User Form To First Empty Row Of Sheets
    Last Post: 08-14-2013, 11:04 PM
  2. Replies: 9
    Last Post: 12-04-2012, 09:45 PM
  3. Macro To Clear Certain Data Across Many Sheets
    Last Post: 12-04-2012, 09:10 AM
  4. Macro to clear data based on color fill
    Last Post: 12-03-2012, 09:25 AM
  5. Adding A Menu Bar To A User Form
    Last Post: 05-05-2011, 04:05 AM
