Thread: Random Unique Value Generator Based On Sample Size And Maximum Items Limit
    Oct 2013
    Question Random Unique Value Generator Based On Sample Size And Maximum Items Limit
    Hi All,
    Thanks for your precious time in supporting me, my need is that i have a set of reference number in my excel sheet and i have desired counts (sample size) that i need to randomly select from the set of reference numbers and allocate them to few persons in next sheet (that i will be input their name and how many reference numbers should be allocated to a particular person, the persons and their count will change daily)
    I uploaded my sample workbook, please download and help me in this regard.
    Pls come back if any of my explanation is not understandable.
    Once again thanks for your precious time.....friends...`
    i have already posted this thread in excel forum for reference pls see below
    Need to organize data based on requirements....explained below
    Jun 2013
    put in K10 the formula
    =COUNTIF($D$2:$D$61,J10)
    Paste this to the code module of the respective sheet and run the macro.
    Sub RandLookUp()
        Dim lng As Long
        Dim lngMax As Long: lngMax = Range("L5").Value
        Dim lngMin As Long: lngMin = Range("K5").Value
        Dim strNames(1 To 5000) As String
        With CreateObject("Scripting.Dictionary")
            Do While .Count <= Range("K7").Value 'lngMax - lngMin          'removed the greater than symbol
                lng = Rnd * (lngMax - lngMin) + lngMin  'removed the +1
                .Item(lng) = Empty
            Loop
            lngMin = Empty
            For lng = 1 To Range("J10:J18").Rows.Count
                If Not IsEmpty(Range("J10:J18").Cells(lng, 1)) Then
                    For lngMax = 1 To Range("J10:J18").Cells(lng, 2).Value
                        lngMin = lngMin + 1
                        strNames(lngMin) = Range("J10:J18").Cells(lng, 1).Value
                    Next lngMax
            Next lng
            Range(Range("A2"), Cells(Rows.Count, 1).End(xlUp)).Resize(, 4).ClearContents
            Range("A2").Resize(Range("K7").Value).Value = Application.Transpose(.Keys)
            Range("B2").Resize(Range("K7").Value, 2).Formula = "=VLOOKUP($A2,Sheet1!$A:B,COLUMN(),0)"
            Range("D2").Resize(Range("K7").Value).Value = Application.Transpose(strNames)
    Oct 2013
    Thanks a lot Admin...
  1. Replies: 10
    Last Post: 08-29-2013, 08:20 PM
  2. Replies: 14
    Last Post: 06-27-2013, 10:57 AM
  3. Unique Random Number In Ascending Order
    Last Post: 11-04-2012, 04:15 PM
  4. Random Unique Number Generator Excel VBA
    Last Post: 10-18-2012, 01:00 PM
  5. Create Random Number Generator VBA
    Last Post: 12-01-2011, 10:51 AM
