hi all,
I have a problem with regards to worksheet referencing. I have a workbook with 3 sheets. Sheet 1 and 2 contain the data while sheet 3 contains the command button that calls a userform.
in sheet 3 there are the active & vacant button for sheet 1 and 2 that when clicked will call a userform. in the userform there is a combobox that will contain the value based on sheet 1 and 2. if the sheet1 active button is clicked the userform combobox will display the active channels based on sheet1, same with sheet 1 vacant channel.. sheet2 vacant and active button will do the same from sheet 2.
My problem is i cannot reference the commandbutton code to the right sheet. it only works when the active/vacant commanduttons is located in sheet 1 and sheet2 but when they are located in sheet 3 and sheet 1 and 2 are hidden, it does not work.
I attached a copy of my workbook for your reference.
Regards,
rydysh
