Thread: How To Add Numbers Having Beginning And Ending Trailing Space
    Aug 2013
    Hi All,
    I have numeric data with beginning space, also the format of same is not calculating sum. (If beginning space removed manfully still it will not show as number style / format)
    Right now I using formula =SUBSTITUTE (target cell,CHAR(160)," ")+0 , if there is any code to this work easier.
    The sample of same is attached herewith for your reference
    Thanks in advance
    Regards
    Amar K
    Use this =SUMPRODUCT(--SUBSTITUTE(B2:B40,CHAR(160),0))
    Aug 2013
    Thanks Sir,
    Thanks for your prompt reply, formula are working perfect.
    But interval of I received files at my end is very high, so it will very help full to me to run by any codes.
    Thanks for your valuable information and knowledge sharing
    Regards
    Amar K
  1. Replies: 2
    Last Post: 07-18-2013, 03:34 AM
  2. Replies: 9
    Last Post: 05-22-2013, 09:12 PM
  3. Macro To Delete Numbers With Trailing Character
    Last Post: 04-05-2013, 08:14 PM
  4. Macro to delete trailing X's
    Last Post: 03-29-2013, 12:43 PM
  5. Available Drive Space / Used Space
    By JimHol in forum Excel Help
    Last Post: 12-28-2012, 06:57 PM
