Thread: formula help
    Jul 2013
    formula help
    Greetings
    I need help with a formula for adding up amounts
    Sheet 1 date for LOT1 ,LOT 2 & LOT 3 will look at the date in Sheet 2 and from Sheet 3 look at which letter belongs to which LOT...It will then total up the amount for each LOT according to date...eg attached..
    Aug 2013
    Hope this will help you.
    in sheet 2, Copy below formula to column g7 to g28
    =IF(ISNA(MATCH(E7,Sheet3!$F$6:$F$14,0)),IF(ISNA(MA TCH(E7,Sheet3!$G$6:$G$14,0)),IF(ISNA(MATCH(E7,Shee t3!$H$6:$H$14,0)),"","Lot 3"),"Lot 2"),"Lot 1")
    in sheet 1, copy below formula to column g8 to o10
    =SUMIFS(Sheet2!$F$7:$F$28,Sheet2!$D$7:$D$28,Sheet1 !G$7,Sheet2!$G$7:$G$28,Sheet1!$F8)
    In G8:
    =SUMPRODUCT(SUMIFS(Sheet2!$F$7:$F$28,Sheet2!$E$7:$ E$28,Sheet3!$F$7:$F$14,Sheet2!$D$7:$D$28,G$7))
    Replace the highlighted range accordingly for Lot 2 and Lot 3.
