Results 1 to 10 of 11
Thread: Create folder and copy 2 sheets
    Sep 2013
    Hello,
    I would like to help me with the following problem:
    In an excel file I have two spreadsheets, "Main" and "BC"​​. In sheet 1 (called Main) in cell C2 = Month and year in D2. I want to create a folder with the name of the D2, and a file with the name of the C2 here to copy Sheet "Main" and change its name to "Month Year" (C2 & D2), and then copy sheet BC with Name "BC Month Year". The same sheets that were created I want to be copied and the file where the code is released.
    Ex. In sheet "Main" in C2 is May and in D2 = 2012. I want to create a folder named 2012 and here a file named May. This will create sheets "May2012" (which will be copied sheet Main) and "BC May2012" (which will copy the sheet BC).
    Anticipated thanks to everyone who will help me.
    Jun 2013
    attach please a sample file for testing
    Sep 2013
    Patel, thanks for reply.
    I attached a file with no data. Are confidential.
    Jun 2013
    sample file means a file with dummy data, not empty file
    Sep 2013
    Patel,
    Why is it necessary layout of data in the spreadsheet? If I want to copy ALL sheet
    If you need more details, just ask.
    Jun 2013
    It's necessary for me, but you can wait for others answers
    Sep 2013
    Quote Originally Posted by patel View Post
    Patel,
    If you can help me, fine, if not, let others who will ...
    Apr 2012
    With sample data in your spreadsheet, it makes it easier to test the solution to make sure it works before it is posted for your use. It also saves those willing to help from having to re-create your issue using their assumptions of how you set up, formatted and have data.
    Sep 2013
    Quote Originally Posted by alansidman View Post
    It looks like you did not read carefully what I wrote in my post and attached file. Because I want to copy ALL the spreadsheet, why do you need to see the formatting, because it will automatically copy. Then why should be seen spreadsheet format??
    Sep 2013
    Guess all the guys that helped have gone on this site....
  1. Split Workbook In To Sheets, Export To Folder and Move File
    By doug@powerstroke.us in forum Excel Help
    Last Post: 05-22-2013, 06:45 PM
  2. Replies: 7
    Last Post: 05-08-2013, 07:12 PM
  3. VBA -- Copy/Paste across sheets
    Last Post: 09-21-2012, 02:07 PM
  4. Copy Sheets To New Workbook And Save
    By Prabhu in forum Excel Help
    Last Post: 09-06-2011, 09:35 PM
  5. Replies: 0
    Last Post: 04-03-2011, 07:57 PM
