Thread: Adapt VBA Code With Adjusment Range
    Sep 2013
    hii expert...
    would you help me to easy adapt this code which expected result in "sheet2" start from range "k16" drop down
    with source data in sheet "data" and with title/column name as parameter...
    i confused to figure it out, and i 'am newbie
    Sub result()
    Dim lstRow As Long
    Dim i As Long
    Sheet2.Range("B2:C500").Value = "" 'Change as required
    Sheet1.Activate
    lstRow = Range("C" & Rows.Count).End(xlUp).Row
    For i = 2 To lstRow
        If Range("C" & i).Value <> "" Then
        Sheet2.Cells(Rows.Count, Range("B1").Column).End(xlUp).Offset(1, 0).Value _
        = Sheet1.Range("C" & i).Value
        If Range("D" & i).Value <> "" Then
        Sheet2.Cells(Rows.Count, Range("C1").Column).End(xlUp).Offset(1, 0).Value _
        = Sheet1.Range("D" & i).Value
        If Range("E" & i).Value <> "" Then
        = Sheet1.Range("e" & i).Value
        If Range("F" & i).Value <> "" Then
        = Sheet1.Range("F" & i).Value
        If Range("D" & i).Value = "" Then
    Next i
    Sheet2.Activate
    Range("A1").Select
    MsgBox "I think now you are happy after see your desired Answer"
    for anybody help me, much appreciated...
    i attach woorbook
    regards..
    m.susanto
    Sep 2013
    if you are confused. i attach new workbook with show the results completely...
    i hope somebody would help me to make me happy......
    May be..
    Sub kTest()
        Dim rngData     As Range
        Dim rngName     As Range
        Dim rngDest     As Range
        Dim r           As Long
        Dim c           As Long
        Dim p           As Long
        Dim Ofset       As Long
        Ofset = 7
        With Sheet1
            p = .Range("c" & .Rows.Count).End(xlUp).Row
            Set rngName = .Range("c2:c" & p)
            Set rngData = .Range("aj2:at" & p)
        Set rngDest = Sheet2.Range("d32")
        For r = 1 To rngName.Rows.Count
            If Not rngName.Cells(r, 1).Value = vbNullString Then
                rngDest = rngName.Cells(r, 1)
                For c = 1 To rngData.Columns.Count
                    If Not rngData.Cells(r, c).Value = vbNullString Then
                        rngDest.Offset(, Ofset) = rngData.Cells(r, c).Value2
                        Set rngDest = rngDest.Offset(1)
                        If c = 1 Then Set rngDest = rngDest.Offset(1)
                        Exit For
  1. data entry to correct cell range...code needs help
    Last Post: 08-28-2013, 05:26 PM
  2. Replies: 1
    Last Post: 08-23-2013, 06:33 PM
  3. Shorten VBA Code By Removing Redundant Superfluous Code
    Last Post: 08-15-2013, 09:09 PM
  4. VBA Looping Input Range and Output Range
  5. Replies: 3
    Last Post: 01-28-2013, 11:01 PM
