Results 1 to 7 of 7
Thread: fill in cells according to selected optionbutton
    Mar 2013
    I have the cells fill in with color for Production,Planned Stop and Internal for Machine Stoppage......
    1. How can the code be changed so that when Machine Stoppage is used it fills in the cells (eg XFLOW A Sheet) with color depending on which is selected between Internal or External...i can get it to fill in for Internal but not External
    2. When Daily Total is selected (commandbutton) it also colors the rows where all Sum Totals are ... can the rows which have any Totals and Grand Totals entered have NO color in these rows
    PP
    Mar 2013
    Moderator
    Jul 2012
                With .Range("B" & Rows.Count).End(xlUp)
                    .Offset(, 1).Resize(, 16).Interior.ColorIndex = 34
                    .Offset(, IIf(OptionButton4, 8, 13)).Resize(, 5).Interior.ColorIndex = xlNone
    Sub SubTotalize()
        With Sheets("XFLOW A")
           .Unprotect Password:="abc"
           .Range("B7:Q" & .Cells(Rows.Count, 2).End(xlUp).Row).Subtotal GroupBy:=1, Function:=xlSum, TotalList:=Array(3, 4, 7, 12, 16), Replace:=True, PageBreaks:=False, SummaryBelowData:=True
                .Offset(-1, 1).Resize(2, 16).Interior.ColorIndex = xlNone
           .Protect UserInterfaceOnly:=True, Password:="abc"
    Mar 2013
    Thanks Bakerman
    I am confident this is the last part and the workbook is completed
    If i run this code below with no entries in the data sheet it brings up an error...can something be added in the code so that if no data is on the sheet it brings up a message "no data to sum" .. this will stop the error
    Sub SubTotalize()
    Mar 2013
    Another
    On the data sheet XFLOW A for 13/9/2013 & 14/9/2013 for Total the rows are blue....can all rows with either Total or Grand Total have no color
    Thanks again
    Moderator
    Jul 2012
    Put this on top off SubTotalize.
    If Sheets("XFLOW A").Range("B6").CurrentRegion.Rows.Count = 2 Then Exit Sub
    Mar 2013
    Thanks bakerman
    Can this one be fixed...if so this is finished
    Thanks again
  1. Replies: 1
    Last Post: 08-20-2013, 04:31 PM
  2. Replies: 9
    Last Post: 08-02-2013, 07:55 PM
  3. Unmerge Cells and Fill with Duplicate Values
    Last Post: 10-09-2012, 07:36 AM
  4. Replies: 2
    Last Post: 09-24-2012, 06:24 PM
  5. Replies: 0
    Last Post: 02-27-2012, 01:07 AM
