Results 11 to 20 of 25
Thread: changing code from using Combobox to optionbuttons
  1. #11
    Moderator
    Jul 2012
    My guess the best option would be to put them in 1 frame so you select either one of them. Otherwise you should put an extra button to enable both frames when you change your mind.
  2. #12
    or give them the same 'groupname'
  3. #13
    Mar 2013
    I did have a version where I placed all in the 1 frame...I am stilling working on it but it does work on some features.The issues I am having is if I select Internal and its selections from the combobox`s it works as it renders External combobox`s disabled.If i then change to External is keeps the selections in the combobox`s also from Internal so it ends up transferring both Internal and External combobox`s......if I select Internal and its combobox`s only it works fine......same for External
    I also have userform Production and Planned Stop now working
    How do I give the same Groupname.....is this in properties?
    Moderator
    Jul 2012
    Combobox issue resolved.
    Mar 2013
    Thanks bakerman
    Works....if i select Internal or External can the Time textbox`s also be disabled (entry deleted) on the 1 not selected.
    If changing from say Internal to External it removes the entries in the Combobox`s but not the Textbox.......i will attempt to resolve this so would i need to add code in the Optionbutton4 and 5 parts of the code
    Thanks again
  6. #16
    Moderator
    Jul 2012
    Try it this way.
    Private Sub OptionButton4_Click()
        For i = 2 To 6
            With Me("Combobox" & i)
                .Value = vbNullString
                .Enabled = IIf(i <= 4, True, False)
            If i = 2 Or i = 3 Then
                With Me("Textbox" & i)
                    .Text = vbNullString
                    .Enabled = IIf(i = 2, True, False)
    Private Sub OptionButton5_Click()
        For i = 2 To 6
                .Enabled = IIf(i <= 4, False, True)
                    .Enabled = IIf(i <> 3, False, True)
    Mar 2013
    Thanks for all your help bakerman...the code above worked
    I did find 2 errors...i used the Tag property in the userform for the Combobox`s and Textbox`s and they work...i used the Tag Property for the Optionbuttons for XFLOW A+B+C also but if i transfer the userform without selecting XFLOW A or B or C it gives a Runtime error...i thought the Tag property would stop this error...
    Also if i do not select External or Internal i can then select all the Combobox`s and Textbox`s in the frame......is there a way to force either Internal or External to be selected
    Paul
  8. #18
    Moderator
    Jul 2012
    1) Remove the Tags from XFLOW A+B+C and put next code on top of CommandButton1_Click.
        For Each ctl In Frame1.Controls
            If TypeName(ctl) = "OptionButton" Then
                If ctl.Value = False Then x = x + 1
        If x = 3 Then MsgBox "Select a machine before you write data": Exit Sub
    2) In designmode set the Enabled-property of the CB's and both TB's to False.
  9. #19
    Mar 2013
    Thanks bakerman
    Added the code (possibly in the wrong place) and set the Enabled-property of the CB's and both TB's to False
    If i select date and machine and press Transfer Button it messagebox says "Select a Part"...i press OK and it give a Runtime Error 2110.....
    Could this be where i placed the code as you mentioned on top of CommandButton1_Click...i could not get it to place above the CommandButton1_Click which may cause the error
    Thanks again
    Moderator
    Jul 2012
    Change this line
    If ctl.Value = vbNullString Then MsgBox ctl.Tag: ctl.SetFocus: Exit Sub
    to this line
    If ctl.Value = vbNullString Then MsgBox ctl.Tag: Exit Sub
    The error occured because you can't set focus to a disabled object.
  1. Replies: 8
    Last Post: 08-17-2013, 04:03 AM
  2. Changing Picture Using Data Validation
    By jeff in forum Excel Help
    Last Post: 08-03-2013, 09:39 AM
  3. adding entries into combobox with code
    Last Post: 07-23-2013, 01:01 PM
  4. Changing Slideshow viewing mode to kiosk using vba
    By Times in forum Powerpoint Help
    Last Post: 05-10-2013, 12:37 AM
  5. Changing Hyperlink To Another Sheet By Changing Value Of Cell
    Last Post: 04-30-2011, 11:55 PM
